[VisCom] Re: FW: MODERATE for dev@visibilitycommittee.osgeo.org
Michael P. Gerlek mpg at lizardtech.com
Wed Mar 15 12:42:46 EST 2006
For the past week or so, I've been 'approving' things as soon as they
come in.  (maybe I should just learn to add someone to the approved-list
or something...)
-mpg
> -----Original Message-----
> From: Arnulf Christl [mailto:arnulf.christl at ccgis.de]
> Sent: Wednesday, March 15, 2006 9:42 AM
> To: dev at visibilitycommittee.osgeo.org
> Subject: [VisCom] Re: FW: MODERATE for
> Michael P. Gerlek wrote:
> > Ummm...  I saw Markus' post go through -- presumably someone did the
> > 'approval'?
> > -mpg
> Someone was me. Was it wrong? Who else is someone and can approve? I
> would like to share this reponsibility, else people will have to wait
> until i find these mails in my inbox and you don't want to see what
> currently is going on there...
> > From:
> dev-reject-1141409874.32000.gbdefnahacoelggdpmja at visibilitycom
> mittee.osg
> > eo.org
> [mailto:dev-reject-1141409874.32000.gbdefnahacoelggdpmja at visib
> ilitycommi
> > ttee.osgeo.org]
> > Sent: Friday, March 03, 2006 10:18 AM
> > Cc:
> dev-allow-tc.1141409874.ilalejkjdgafcphgpeeb-neteler.osgeo=gma
> il.com at vis
> > Subject: MODERATE for dev at visibilitycommittee.osgeo.org
> > The enclosed message was submitted to the
> > mailing list. If you'd like to approve it for distribution to all
> > the subscribers, please e-mail:
> dev-accept-1141409874.32000.gbdefnahacoelggdpmja at visibilitycom
> mittee.osg
> > eo.org
> > Usually, this happens when you just hit the "reply" button. You can
> > check the address to make sure that it starts with
> > "dev-accept". If this does not work, simply copy the
> > address and paste it into the "To:" field of a new message.
> > To reject the post and cause it to be returned to the
> > sender, please send a message to:
> mittee.osg
> > eo.org
> > Usually, it is easiest to hit the "reply-to-all" button, and then
> > remove all the addresses except the one starting with
> > "dev-reject".
> > You do not need to copy the post in your response to accept or
> > reject it. If you wish to send a comment to the sender of a rejected
> > post, please include it between two marker lines starting with three
> > percent signs ('%'):
> > %%% Start comment
> > %%% End comment
> > Thank you for your help!
> > --- Enclosed, please find the posted message.
> > Subject:
> > test only MN
> > From:
> > "Markus Neteler" <neteler.osgeo at gmail.com>
> > Date:
> > Fri, 3 Mar 2006 10:17:52 -0800
> > To:
> > "OSGeo VisibCom" <dev at visibilitycommittee.osgeo.org>
> > To:
> > Hi,
> > not sure if I receive mails here...
> > Markus
> > To unsubscribe, e-mail:
> dev-unsubscribe at visibilitycommittee.osgeo.org
> > For additional commands, e-mail:
> dev-help at visibilitycommittee.osgeo.org
> To unsubscribe, e-mail: dev-unsubscribe at visibilitycommittee.osgeo.org
More information about the Viscom-dev mailing list
