[VisCom] Presentation Templates
Michael P. Gerlek
mpg at lizardtech.com
Wed Sep 27 17:19:35 EDT 2006
Done.
-mpg
> -----Original Message-----
> From: Arnulf Christl [mailto:arnulf.christl at ccgis.de]
> Sent: Wednesday, September 27, 2006 11:33 AM
> To: dev at visibilitycommittee.osgeo.org
> Subject: Re: [VisCom] Presentation Templates
> Michael P. Gerlek wrote:
> > I only did that because (I think?) the CN file system
> doesn't support
> > versioning.
> > Should just make a subdir called "OLD" or something, or
> just blow away
> > the old version and stop worrying?
> late runner up...
> "blow away the old version and stop worrying" is the correct
> process. We should try to keep the library concise and clean,
> it is already hard enough to find the required documents.
> There are already documents in other languages makign it even
> harder to keep track of what is going on. And there are some
> metadata fields that can be used during upload and there is a
> status (from draft to archived) that helps orientation.
> I have no idea how this library might be managed using the
> drupal site. We should start working on that and get rid of
> the current thing asap.
> Regards, Arnulf.
> > -mpg
> >> From: Markus Neteler [mailto:neteler.osgeo at gmail.com]
> >> Sent: Saturday, September 09, 2006 8:03 AM
> >> Thanks.
> >> But let me suggest to delete "Presentation Template - v1.opt"
> >> (I don't see any sense in keeping it) and rename
> >> "Presentation Template - v2" to "Presentation Template".
> >> Just one template should be enough.
> >> thanks
> >> Markus
> >> On 9/9/06, Michael P. Gerlek <mpg at lizardtech.com> wrote:
> >>> Done. It is buried down in
> >> https://visibilitycommittee.osgeo.org/servlets/ProjectDocument
> >> List?folde
> >>> rID=54 and named "presentation Template - v2".
> >>> (I so hate our CN-based library...)
> >>> -mpg
> >>>> Sent: Wednesday, September 06, 2006 5:01 AM
> >>>> Hi Arnulf, mpg,
> >>>> I have fixed the (for me) annoying problem that "Times" font was
> >>>> predefined in the template. Please update the template in the
> >>>> OSGeo library, grab the new file here:
> >>>> http://mpa.itc.it/markus/osgeo/
> >>>> cheers
> >>>> Markus
> >>>>>> Yes, that's the right one. Be warned, though, that
> >>>> although the design is okay the implementation has issues --
> >>>> you'll likely have to tweak the font sizes, indenting,
> >>>> bullets, etc, to make things look nice.
> >>>>>> -mpg
> >>>>> Whatever is tweaked should find its way back to the
> >> library. I would
> >>>>> like to put that stuff into the VisCom SVN, we even have
> >>>> size issues, A4
> >>>>> and US-letter and will need to put in some effort to
> >> make sure that
> >>>>> there are up-to-date versions for all languages. The
> >>>> documents & files
> >>>>> of the CN structure does not provide enough information
> >> and linking
> >>>>> possibilities. Sounds like we need to have a VisCom sprint.
> >>>> Anybody run
> >>>>> for this? Maybe this can be done as an IRC meeting.
> >>>>> Regards,
> >>>>>> Sent: Mon 9/4/2006 6:36 AM
> >>>>>> Subject: [VisCom] Presentation Templates
> >>>>>> Hi Michael,
> >>>>>> I added a link to the OSGeo template from the VisCom
> >>>> library section for
> >>>>>> people having a presentation at FOSS4G:
> http://wiki.osgeo.org/index.php/OSGeo_at_FOSS4G2006#Talk_Presentations
> >>>>>> Could you please confirm that this is the right link?
> >>>>>> Thanks a lot,
> >>>>>> Arnulf.
> >>>>> To unsubscribe, e-mail:
> >>>> dev-unsubscribe at visibilitycommittee.osgeo.org
> >>>>> For additional commands, e-mail:
> >>>> dev-help at visibilitycommittee.osgeo.org
> >>>> Open Source Geospatial Foundation
> >>>> http://www.osgeo.org/
> >> http://grass.osgeo.org/
> To unsubscribe, e-mail: dev-unsubscribe at visibilitycommittee.osgeo.org
More information about the Viscom-dev
