[Viscom-dev] RE: [Webcom] Drupal settings for www.osgeo.org
Jason Birch
Jason.Birch at nanaimo.ca
Sat Feb 3 18:06:52 EST 2007
Arnulf,
No toes stepped on here. This is another area that should be under control of the most effective party, just like the committee and local chapter areas.
I agree with you that a document management system needs to be set up for VisCom, and with most of the suggestions that you have made. SAC folks, is there someone there that can help Arnulf with these requests? Tyler, do you know how to do this? Also, do we need to somehow separate out the project-level Drupal sites so that they don't share files?
Arnulf it sounds like you have considerably experience with Drupal, while many of us are still learning. I would certainly support SAC granting you access to the server to help with this setup... as long as you don't get carried away ;-)
Once we figure out how to get there from here, this should probably go into our cool new Trac as a task for either WebCom or SAC.
http://trac.osgeo.org/trac/osgeo/report/1 <http://trac.osgeo.org/osgeo/>
Jason
From: webcom-bounces at lists.osgeo.org on behalf of Arnulf Christl
Sent: Sat 2007-02-03 2:10 AM
To: webcom at lists.osgeo.org
Cc: viscom-dev at lists.osgeo.org
Subject: [Webcom] Drupal settings for www.osgeo.org
currently all images that are uploaded to the http://www.osgeo.org
"instance" of Drupal end up in the authenticated user's directory. Due to
the focus of this site being general and not individual this should be
changed to a common shared folder.
Somebody with the required power please create or identify that folder and
change the corresponding configuration here:
http://www.osgeo.org/admin/settings/imce
We are - no, wait - I am still missing a place to upload and manage
documents, especially all that was produced by VisCom (several dozen
documents). This section should also be accessible to broader membership
than just WebCom, at least VisCom must be able to create pages, add files,
remove files and change names at its own discretion.
I am trying to not mess up things (not trying to mess up, messing up not
trying to) and I am not trying to sneak broader access to common folks
through the back door but specify a specific need by VisCom that should be
addressed soon. At the same time VisCom needs to come up with a manageable
way to handle multiple documents.
Additionally I suggest to modify the list of allowed file types to inlcude
odt, odp and zip extension.
Best regards,
Arnulf.
Arnulf Christl
http://www.wheregroup.com
Webcom mailing list
Webcom at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/webcom
More information about the Viscom-dev
