[Viscom-dev] Project Flyer
Arnulf Christl
arnulf.christl at wheregroup.com
Fri Jun 1 13:47:35 EDT 2007
Tyler Mitchell (OSGeo) wrote:
> These fliers are good, but is there an update overview flier? Also, the
> main item we were posting from http://www.osgeo.org/visibility was a
> single PDF with a separate page for each project. Can you easily
> produce this? Then I can update that page.
> Tyler
Stephan and Hendrik are at the LinuxTag exhibition and conference where OSGeo operates a booth together with GAV, OSM and FreeGIS. Same procedure as last year - OSM is *the* magnet for the kind of folks showing up at LinuxTag. But the OSGeo Flyers are also well accepted, several hundreds have been picked up already, they had to go print more copies.
When they are back next week they will clean up the flyers and produce individual PDFs, I guess that some also have to be translated back into English as well.
Regards, Arnulf.
> On 30-May-07, at 8:06 AM, Arnulf Christl wrote:
>> Hi Tyler,
>> Stephan and Hendrik have sent you updated project flyers including the
>> new projects QGIS, OpenLayers, FDO and GeoNetwork. Skribus seems to
>> have been somewhat reluctant to cooperate - at least I gather that
>> from the complaints that I heard from the next room while they were at
>> it... Are we going to stick with Skribus for this job? Next question
>> is how to get the Projects update and maintain their Info sheets
>> themselves. We went through all of them once now to have a stable
>> baseline but from now on maintenance needs to be done by the projects
>> themselves. Maybe we can do the same thing as I suggested for the
>> portal pages. Make a Wiki page and use that plus some nice layout in
>> Skribus to produce the Flyers.
>> Maybe you could put the PDFs on the web and remove the tag saying that
>> they are still being worked over? http://www.osgeo.org/visibility
>> We are trying to consolidate some of our outward visibility stuff.
>> Best regards, Arnulf. _______________________________________________
>> Viscom-dev mailing list
>> Viscom-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/viscom-dev
> Tyler Mitchell
> Executive Director
> Open Source Geospatial Foundation
> tmitchell at osgeo.org
> P: +1-250-277-1621
> M: +1-250-303-1831
More information about the Viscom-dev
