[Web Comm] Drupal Transition and Automated Web Page Cleanup
Tyler Mitchell
tylermitchell at shaw.ca
Fri Dec 1 18:23:58 EST 2006
Sorry, this mail client program makes it hard to add comments.
Drupals accepts, out-of-the-box: limited HTML (small set of tags), plain text, full HTML or PHP code (usually disabled for public contributors for security purposes).
Drupal stores exactly what you enter, but you then tell it what the type of code/text is - i.e. Is it full HTML or is it PHP - and, if you have permissions it will serve all the content up exactly as you entered it. This means there can be, literally, no effort or cleanup required to get our current content ported.
Tyler
-----Original Message-----
Sent: Fri, 01 Dec 2006 19:06:09 -0500
To: dev at webcommittee.osgeo.org
CC: kanhaiya.kale at gmail.com, mateusz at loskot.net
Received: Fri, 01 Dec 2006 22:59:59 +0000
Subject: Re: [Web Comm] Drupal Transition and Automated Web Page Cleanup
Tyler Mitchell wrote:
> Hi all,
> By default we can have drupal ignore everything but the most basic content. It will simply not display it.
> I would like to see clean code but not if it causes any delay without substantial aesthetic improvement. Can we postpone this until after the primary content port is complete? In my opinion it is low priority until the new year.
Tyler,
I am getting the impression that Drupal does not use upload html directly,
but rather it processes it into some internal format, and then produces
new HTML of it's own construction. Is that right?
If that is the case, then we should be planning on human review of all
unusual/non-compliant web pages since we can expect them to subsubstantially
transformed, right?
In this case, we might as well cleanup the web pages as we go, and hopefully
the scripts can identify all pages which had substantial stuff changed
in the process so we can review them manually.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
To unsubscribe, e-mail: dev-unsubscribe at webcommittee.osgeo.org
For additional commands, e-mail: dev-help at webcommittee.osgeo.org
More information about the Webcommittee_dev
