Developer profile?
Markus Neteler neteler.osgeo at gmail.com
Thu Oct 5 09:50:53 EDT 2006
Hi Auke, WebCom,
thanks - I have made a few minor changes (see attached diff and full file V1.3).
best,
Markus
On 10/5/06, Auke Jilderda <auke at collab.net> wrote:
> Hi Markus,
> thanks, looks good!
> I converted your plain text into HTML (revision 1.1) and provided some
> suggestions (revision 1.2).  I thought I'd be smart and use version
> control with the diff to help you easily scan through the feedback but
> that didn't work out as great as I had hoped: my editor re-wrapping
> lines to fit the width obfuscates the diff a bit but I included the diff
> below as well as both files.  The latest version is viewable at [1].
> Note, I didn't publish it anywhere yet until you and the web committee
> is fine with it.
> In general, I fixed some typos and punctuation.  Also, I added a
> reference to your book.  Let me know if you're ok with the current
> version and what you'd like to see changed?
> Web committee, can you also have a look and give feedback?
> Thanks!
> Auke
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/webcommittee_dev/attachments/20061005/e79122f4/diff.obj
URL: http://lists.osgeo.org/pipermail/webcommittee_dev/attachments/20061005/e79122f4/MarkusNeteler.1.3.html
More information about the Webcommittee_dev mailing list
