[Web Comm] Site map research and notes
Jody Garnett
jgarnett at refractions.net
Tue Oct 17 01:45:44 EDT 2006
Jody Garnett wrote:
> Attached is a pdf, I have a few more user stories to go through before
> starting in on the site map. The document contains:
> - review of a similar site (eclipse.org) that has just made the
> transition to a use based work flow
> - review of user stories from the wiki
> - placeholder for site map
> - visual draft (so you do not think I am crazy)
Sorry grabbed the wrong file - here is a pdf. Regardless the power point
file had more information in the "notes" section.
Jody
Type: application/pdf
Desc: not available
Url : http://lists.osgeo.org/pipermail/webcommittee_dev/attachments/20061016/1066b0c5/website.pdf
More information about the Webcommittee_dev
