[Web Comm] content/governance directory
Jason Birch
Jason.Birch at nanaimo.ca
Fri Sep 22 11:00:59 EDT 2006
There's a place in the CollabNet docs showing how an admin can physically remove directories (likely with an rm), but the option never showed up for me when I worked through the instructions. I'd have to hunt around to find it, but I think it's in this group's archives somewhere.
Jason
Sent: Fri 2006-09-22 5:32 AM
To: dev at webcommittee.osgeo.org
Subject: RE: [Web Comm] content/governance directory
Jason, Frank,
CVS does not support removing directories the way one would like. Take
a look at section 7.3 in the Cederqvist manual [1] for a short piece on
removing directories:
"The way that you remove a directory is to remove all the files in
it. You don't remove the directory itself; there is no way to do
that. Instead you specify the `-P' option to cvs update or cvs
checkout, which will cause CVS to remove empty directories from
working directories."
I just removed the one file that says this directory is unused in the
directory so just run "cvs update -P" and you should be good to go.
Auke
1. http://ximbiot.com/cvs/manual/cvs-1.11.22/cvs_7.html#SEC69
On 20 September 2006 17:04, Jason Birch wrote:
> Go ahead if you can figure out how.
> I tried this for ages and even put in a service request to Collabnet
> (Daniel) for it, to no avail. There are other similar empty
> directories out there.
> Jason
To unsubscribe, e-mail: dev-unsubscribe at webcommittee.osgeo.org
For additional commands, e-mail: dev-help at webcommittee.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/webcommittee_dev/attachments/20060922/1caa588f/attachment.bin
More information about the Webcommittee_dev
