[WebCom] Mailing list name
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 10 16:10:33 EST 2007
Jason Birch wrote:
> I'd like to change the mailing list name for webcommittee_dev@ to
> webcom@ , and dump the other webcommittee_* lists.
+1
> I'd also like to rename the www_news-item@ list to news-item@ and dump
> the www_admin@ and www_cvs@ lists.
The www_news-item list isn't used. There is now a news_item at osgeo.org
alias so that list should be blown away.
> Opinions?
> There are quite a few other lists that need cleanup similar to this, but
> there are likely better forums for that cleanup?
There is a more comprehensive list naming thread underway on the sac list
under the assumption that mailing lists are a SAC responsibility.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Webcommittee_dev
