[webmap-discuss] RE: [Context.RWG] Using OWS Context to describe
GML/WFS layers whichdecimate
Cameron Shorter
cameron.shorter at gmail.com
Wed Nov 1 01:01:10 EST 2006
Tom,
Yes using groups would work.
Do you expect to have a proposed schema with the group tag included in
time for me to use it in the OWS4?
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>Sent: 31 October, 2006 7:17 PM
>>To: Kralidis,Tom [Burlington]
>>Cc: Martin Daly; context.rwg at opengeospatial.org;
>>webmap-discuss at mail.osgeo.org; Raj Singh
>>Subject: Re: [Context.RWG] Using OWS Context to describe
>>>Cameron,
>>>So you want one OWSContext FeatureType to hold many GML documents?
>>>If yes, can you not define each GML doc as an OWSContext
>>FeatureType,
>>>each with respective scale rules?
>>Tom,
>>Using Style scale rules to make a layer visible or not would
>>be one solution - but with a number of limitations:
>>1. If I were to build a LayerList (or Legend) from the
>>Context, would I end up with a layer for each scale?
> Yes, however you could build your client Legend handler to show layers
> only if they're within the scale range of where the application scale is
> at.
>>2. If my legend was smart, and layers were only visible at
>>certain resolutions, how do I associate a HighResolutionLayer
>>with a LowResolutionLayer so that the Layer attributes (like
>>visibility) can be associated between layers.
> If OWSContext identified the notion of a @group attribute as part of the
> AbstractResourceType, this might be an option. There has been some mild
> discussion on this front.
>>>>Sent: 30 October, 2006 7:29 PM
>>>>To: Martin Daly
>>>>Cc: context.rwg at opengeospatial.org; Kralidis,Tom [Burlington];
>>>>Subject: Re: [Context.RWG] Using OWS Context to describe GML/WFS
>>>>Martin,
>>>>Point taken regarding G/Y/M maps. Replace zoomLevel with
>>>>sld:Min/MaxScaleDenominator in my previous comment.
>>>>I still need to reference different GML sources for each layer
>>>>depending on scale, which doesn't seem to be covered by OWS Context
>>>>yet.
>>>>Martin Daly wrote:
>>>>>>zoomLevel is a term used by Google/Yahoo/MSN Maps.
>>>>>>It is a measure of resolution. As you zoom out, the zoomLevel
>>>>>>increases.
>>>>>That is not a definition that will wash in a standard that
>>aims for
>>>>>interoperability.
>>>>>In fact, OWS Context already uses
>>sld:Min/MaxScaleDenominator in the
>>>>>AbstractResourceType, so the capability already exists.
>>>>>As with the previous long e-mail trail re. GYM data, this
>>>>spec. should
>>>>>leverage de jure OGC standards, not de facto ones that
>>>>large parts of
>>>>>the target audience cannot use.
>>>>>M
>>>>Cameron Shorter
>>>>http://cameron.shorter.net
>>Cameron Shorter
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
Cameron Shorter
More information about the Webmap-discuss
