Using OWS Context to describe GML/WFS layers which decimate
Cameron Shorter cameron.shorter at gmail.com
Sun Oct 29 19:26:50 EST 2006
Tom Kralidis,
As part of OWS4, I'm using rendering GML layers in a web browser, and
using OWS Context to describe the layers.
The use case I'm having problem with is how to render large datasets
when the user zooms out, which means you have to render a huge number of
points.
The usual solution is to decimate the features as you zoom out. Ie,
reduce the number of points rendered. However, I don't think I can
describe this using the current OWS Context.
I assume the best solution would be to filter on the zoomLevel, and use
a different data source for each zoomLevel or resolution, which I
believe would require a change to the OWS Context spec.
<FeatureType hidden="0">
   <Server service="OGC:GML" version="2.1.2" title="Local">
     <Filter xmlns:gml="http://www.opengis.net/gml">
       <PropertyIsEqualTo>
          <PropertyName>ZoomLevel</PropertyName>
          <Literal>2</Literal>
        </PropertyIsEqualTo>
     </Filter>
     <OnlineResource xlink:type="simple"
xlink:href="tasmania/TasmaniaRoads2.xml"/>
   </Server>
   <Server>
       <PropertyIsEqualTo>
          <Literal>3</Literal>
     </Filter>
xlink:href="tasmania/TasmaniaRoads3.xml"/>
   </Server>
   <Name>topp:tasmania_roads</Name>
</FeatureType>
I'm open to suggestions here.
Cameron Shorter
http://cameron.shorter.net
More information about the Webmap-discuss mailing list
