[Context.RWG] Using OWS Context to describe GML/WFS layers whichdecimate
Cameron Shorter cameron.shorter at gmail.com
Tue Oct 31 19:17:11 EST 2006
Kralidis,Tom [Burlington] wrote:
> Cameron,
> So you want one OWSContext FeatureType to hold many GML documents?
> If yes, can you not define each GML doc as an OWSContext FeatureType,
> each with respective scale rules?
Tom,
Using Style scale rules to make a layer visible or not would be one
solution - but with a number of limitations:
1. If I were to build a LayerList (or Legend) from the Context, would I
end up with a layer for each scale?
2. If my legend was smart, and layers were only visible at certain
resolutions, how do I associate a HighResolutionLayer with a
LowResolutionLayer so that the Layer attributes (like visibility) can be
associated between layers.
>>-----Original Message-----
>>From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>Sent: 30 October, 2006 7:29 PM
>>To: Martin Daly
>>Cc: context.rwg at opengeospatial.org; Kralidis,Tom
>>[Burlington]; webmap-discuss at mail.osgeo.org; Raj Singh
>>Subject: Re: [Context.RWG] Using OWS Context to describe
>>Martin,
>>Point taken regarding G/Y/M maps. Replace zoomLevel with
>>sld:Min/MaxScaleDenominator in my previous comment.
>>I still need to reference different GML sources for each
>>layer depending on scale, which doesn't seem to be covered by
>>OWS Context yet.
>>Martin Daly wrote:
>>>>zoomLevel is a term used by Google/Yahoo/MSN Maps.
>>>>It is a measure of resolution. As you zoom out, the zoomLevel
>>>>increases.
>>>That is not a definition that will wash in a standard that aims for
>>>interoperability.
>>>In fact, OWS Context already uses sld:Min/MaxScaleDenominator in the
>>>AbstractResourceType, so the capability already exists.
>>>As with the previous long e-mail trail re. GYM data, this
>>spec. should
>>>leverage de jure OGC standards, not de facto ones that
>>large parts of
>>>the target audience cannot use.
>>>M
>>Cameron Shorter
>>http://cameron.shorter.net
Cameron Shorter
More information about the Webmap-discuss mailing list
