[Wps-discuss] WPS Benchmarking at FOSS4G 2014
Benjamin Proß
b.pross at 52north.org
Thu Sep 4 03:54:31 PDT 2014
Hi all,
Are there any news regarding the benchmark procedure? Or are you all
busy writing comments for the WPS 2.0 candidate standard? :)
Cheers,
Benjamin
Am 21.08.2014 13:00, schrieb Benjamin Proß:
> Hello Gérald, all,
> I am glad that you like the idea and I hope the other projects feel
> the same. The tests you are suggesting make sense, though I am not
> completely sure about the combinations with the complexdata in-/output
> as reference/inline xml. Complexdata output could also be requested as
> raw data output. Maybe we should create a table listing the
> combinations. I could start this and then we could choose the ones we
> want. We should also define the process description, so the projects
> can create the respective processes.
> Cheers,
> Benjamin
> Am 21.08.2014 11:16, schrieb Fenoy Gerald:
>> Hello Benjamin,
>> I think it is a great idea to handle testings of the Execute request
>> the way you described, by using a simple echo service.
>> By now for synchronous requests, the tests look like the following:
>> • Test 1: value as JSON
>> • Test 2: value as GML
>> • Test 3: value as reference as GML
>> • Test 4: same as test 3, result as reference
>> • Test 5: value as reference as GML using POST request
>> • Test 6: same as test 5, result as reference
>> And for asynchronous request, we have the following:
>> • Test 1': value as reference as GML
>> • Test 2': same as test 1, result as reference
>> • Test 3': value as reference as GML using POST request
>> • Test 4': same as test 3, result as reference
>> Personally, I think that the Test 1 and Test 2 should become unique
>> now as there is no need for parsing any value from the service itself
>> as it will simply return the value without any treatment. So we
>> should use only the Test 2 for our next run.
>> I also suppose that we should multiply the number of tests as we will
>> need to ask for each available outputs individually and all the
>> possible combinaisons of them to also test this cases.
>> So, I would like to propose the following updates for the tests run
>> for both synchronous and asynchronous requests. We run each
>> individual test 7 times: first to have only once output at a time (so
>> 3 tests), then to test all possible combinaisons of 2 outputs names
>> (3 tests) and finally to have all the output returned (1 test).
>> I hope that you can confirm that I’m right thinking of this updates
>> to the current tests.
>> I’ve added one column to the table [1] listing all WPS team
>> participating to write the name of the echo service when it will be
>> available.
>> Best regards,
>> [1]
>> http://wiki.osgeo.org/wiki/WPS_benchmark_2014#Available_infrastructure
>> Le 19 août 2014 à 16:03, Benjamin Proß <b.pross at 52north.org> a écrit :
>>> Dear all,
>>> I see that there are still not all services are deployed on the test
>>> machine. I hope you guys are still on board.
>>> At 52°North we were thinking a bit about the execute tests.
>>> We do not yet have any results to compare but we think that
>>> benchmarking with "real" processes that compute something could
>>> falsify the results, as the computation in most cases is done by a
>>> underlying library (GeoTools in our case, but this could also be
>>> exchanged).
>>> So the results would be influenced by how fast the geo-computation
>>> lib would do its job. Not sure that we want that?!
>>> We also do not test whether the process really did its job (e.g.
>>> buffer the input geometry). So do we need to use "real" processes?
>>> We would propose to use an echo process that could have three
>>> inputs, Literal-, Complex- and BBoxData. The process then simply
>>> returns what it gets (input/output types would have to match).
>>> We would probably also need a asynchronous version that has a delay
>>> or something.
>>> That way we could test the input-/output handling capabilities (of
>>> all three data types) of the services and we would still test
>>> everything regarding execute that is tested right now (i.e. we would
>>> not loose functionality).
>>> Do you have any views on that?
>>> Cheers,
>>> Benjamin
>>> Benjamin Proß
>>> Software Engineer
>>> 52°North Geoprocessing Community
>>> 52°North Initiative for Geospatial Open Source Software GmbH
>>> Martin-Luther-King-Weg 24
>>> Fon: +49-(0)-251–396371-42
>>> Fax: +49-(0)-251–396371-11
>>> http://52north.org/
>>> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
>>> Local Court Muenster HRB 10849
>>> Wps-discuss mailing list
>>> Wps-discuss at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/wps-discuss
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
Benjamin Proß
Software Engineer
http://52north.org/
More information about the Wps-discuss
