[Wps-discuss] [WPS-dev] WPS 1.0.0 CITE tests
Benjamin Proß
b.pross at 52north.org
Wed Jun 1 07:21:41 PDT 2016
Alright, I will talk to the CITE test developers next. @Peter, I think
on the client side the Team Engine will be used [1]. The current beta
version of the WPS executable test suite is available here [2].
There is a public Website for executing the current WPS tests [3]. Once
the test suite is released, it will be moved to the official CITE test
Website [4].
I will keep you posted about the progress.
Cheers,
Benjamin
[1] https://github.com/opengeospatial/teamengine
[2] https://github.com/opengeospatial/ets-wps10
[3] http://cite.opengeospatial.org/te2/
[4] http://cite.opengeospatial.org/teamengine/
Am 31.05.2016 um 20:30 schrieb Jachym Cepicky:
> Hi,
> yes, immplementation of such process should be straight forward
> pá 20. 5. 2016 v 16:11 odesílatel Peter Schut via WPS-dev
> <wps-dev at lists.opengeospatial.org
> <mailto:wps-dev at lists.opengeospatial.org>> napsal:
> Hi Benjamin,
> I would be happy to implement part or all of the test suite in my
> own personal WPS implementation. (It's written in Ruby, and not
> open-source). I'd also be interested in working on and
> potentially hosting a publicly-accessible client that could be
> used to run compliance testing.
> Cheers, Peter.
> On Thu, May 19, 2016 at 9:53 AM, Benjamin Proß
> <mailto:wps-dev at lists.opengeospatial.org>> wrote:
> Dear WPS implementers,
> A while (well, almost 2 years...) ago we talked about OGC CITE
> tests for WPS 1.0.0 and how the execute operation could be tested.
> The Abstract Test Suite of the WPS 1.0.0 standard (05-007r7,
> see[1]) describes the following tests for execute (see annex A
> 4.4):
> Test HTTP GET (if advertised/supported by the WPS)
> Test HTTP POST
> Test execute with output set to raw data (literal-, complex-,
> boundingboxdata)
> Test execute with output set to response document (literal-,
> complex-, boundingboxdata)
> Test execute with response storing and status updates (if
> advertised/supported by the WPS/process)
> Test language selection for execute
> Now the issue here is that we need a process to test the
> execute operation. We talked about using a simple
> echo-process, that takes one of each data types as input and
> output.
> I attached an example process description. Things like the
> identifier, formats, datatypes and supported CRS' need to be
> discussed.
> But apart from that.. What do you think, would you be able to
> provide such a process in your WPS framework?
> Cheers,
> Benjamin
> [1] http://portal.opengeospatial.org/files/?artifact_id=24151
> Benjamin Proß
> Software Engineer
> 52°North Geoprocessing Community
> 52°North Initiative for Geospatial Open Source Software GmbH
> Martin-Luther-King-Weg 24
> Fon:+49-(0)-251–396371-42 <tel:%2B49-%280%29-251%E2%80%93396371-42>
> Fax:+49-(0)-251–396371-11 <tel:%2B49-%280%29-251%E2%80%93396371-11>
> b.pross at 52north.org <mailto:b.pross at 52north.org>
> http://52north.org/
> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
> Local Court Muenster HRB 10849
> WPS-dev mailing list
> WPS-dev at lists.opengeospatial.org
> <mailto:WPS-dev at lists.opengeospatial.org>
> https://lists.opengeospatial.org/mailman/listinfo/wps-dev
Benjamin Proß
Software Engineer
Fon: +49-(0)-251–396371-42
Fax: +49-(0)-251–396371-11
http://52north.org/
URL: <http://lists.osgeo.org/pipermail/wps-discuss/attachments/20160601/7a780209/attachment.html>
More information about the Wps-discuss
