[Wps-discuss] [WPS-dev] WPS 1.0.0 CITE tests
Jachym Cepicky
jachym.cepicky at gmail.com
Tue May 31 11:30:27 PDT 2016
yes, immplementation of such process should be straight forward
pá 20. 5. 2016 v 16:11 odesílatel Peter Schut via WPS-dev <
wps-dev at lists.opengeospatial.org> napsal:
> Hi Benjamin,
> I would be happy to implement part or all of the test suite in my own
> personal WPS implementation. (It's written in Ruby, and not open-source).
> I'd also be interested in working on and potentially hosting a
> publicly-accessible client that could be used to run compliance testing.
> Cheers, Peter.
> On Thu, May 19, 2016 at 9:53 AM, Benjamin Proß <
> wps-dev at lists.opengeospatial.org> wrote:
>> Dear WPS implementers,
>> A while (well, almost 2 years...) ago we talked about OGC CITE tests for
>> WPS 1.0.0 and how the execute operation could be tested.
>> The Abstract Test Suite of the WPS 1.0.0 standard (05-007r7, see[1])
>> describes the following tests for execute (see annex A 4.4):
>> Test HTTP GET (if advertised/supported by the WPS)
>> Test HTTP POST
>> Test execute with output set to raw data (literal-, complex-,
>> boundingboxdata)
>> Test execute with output set to response document (literal-, complex-,
>> boundingboxdata)
>> Test execute with response storing and status updates (if
>> advertised/supported by the WPS/process)
>> Test language selection for execute
>> Now the issue here is that we need a process to test the execute
>> operation. We talked about using a simple echo-process, that takes one of
>> each data types as input and output.
>> I attached an example process description. Things like the identifier,
>> formats, datatypes and supported CRS' need to be discussed.
>> But apart from that.. What do you think, would you be able to provide
>> such a process in your WPS framework?
>> Cheers,
>> Benjamin
>> [1] http://portal.opengeospatial.org/files/?artifact_id=24151
>> Benjamin Proß
>> Software Engineer
>> 52°North Geoprocessing Community
>> 52°North Initiative for Geospatial Open Source Software GmbH
>> Martin-Luther-King-Weg 24
>> Fon: +49-(0)-251–396371-42
>> Fax: +49-(0)-251–396371-11b.pross at 52north.orghttp://52north.org/
>> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
>> Local Court Muenster HRB 10849
>> WPS-dev mailing list
>> WPS-dev at lists.opengeospatial.org
>> https://lists.opengeospatial.org/mailman/listinfo/wps-dev
URL: <http://lists.osgeo.org/pipermail/wps-discuss/attachments/20160531/29200808/attachment.html>
More information about the Wps-discuss
