[ZOO-Discuss] GRASS WPS Process Description
Gérald Fenoy gerald.fenoy at geolabs.fr
Fri Nov 27 15:20:16 PST 2009
Hi Markus,
nice to hear from you again.
There is something in the DescribeProcess which make me wondering if I'm wrong or miss something (or maybe the last version of WPS proposal ??). Why was ComplexOutput used where ComplexData should be used ?
Table 46 of the WPS proposal define the Data structure and seems to define that we have to use ComplexData rather than ComplexOutput.
Furthermore, you use a node for MimeType, I've understood that in the WPS proposal, when they use the first letter capitalized that means that we have to use a node. But for mimeType it was specified as-is, so I'm pretty sure that it have to be used as an attribute of the ComplexData node. Please correct me if I'm wrong.
Maybe that's why we have to create a parser to be able to use the DescribeProcess as source for creating the zcfg file which specify the process' metadata.
Hope to hear from you soon,
best regards,
Le 27 nov. 2009 à 21:12, Markus Neteler a écrit :
> Hi all,
> yes, it's there now!
> GRASS 7: new WPS process description can be automatically
> generated thanks to Soeren
> http://grass.osgeo.org/wiki/WPS
> On Fri, Nov 27, 2009 at 09:14, rldhont <rldhont at gmail.com> wrote:
>> Well Gérald, What do you think about it ? Do you have to create a GRASS
>> Provider, like C or Python ? How to re-use this capability ?
> Would be great! The new direct support in GRASS should make things
> finally easier.
> Markus
> PS:
> Example:
> r.external --wps-process-description
>     <?xml version="1.0" encoding="UTF-8"?>
>     <wps:process_descriptions xmlns:wps="http://www.opengis.net/wps/1.0.0"
>     xmlns:ows="http://www.opengis.net/ows/1.1"
>     xmlns:xlink="http://www.w3.org/1999/xlink"
>     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>     xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
>      http://schemas.opengis.net/wps/1.0.0/wpsDescribeProcess_response.xsd"
>      service="WPS" version="1.0.0" xml:lang="en-US">
>       <process_description wps:processVersion="1"
> storeSupported="true" statusSupported="true">
>                               <ows:Identifier>r.external</ows:Identifier>
>                               <ows:Title>Link GDAL supported raster
> file to a binary raster map layer.</ows:Title>
>                               <ows:Abstract>Link GDAL supported
> raster file to a binary raster map layer.</ows:Abstract>
>               <ows:Metadata xlink:title="raster" />
>               <ows:Metadata xlink:title="import" />
>               <data_inputs>
>                       <Input minOccurs="0" maxOccurs="1">
>                               <ows:Identifier>input</ows:Identifier>
>                               <ows:Title>Raster file to be linked</ows:Title>
>                               <ows:Abstract>Raster file to be
> linked</ows:Abstract>
>                               <LiteralData>
>                                       <ows:DataType
> ows:reference="xs:string">string</ows:DataType>
>                                       <ows:AnyValue/>
>                               </LiteralData>
>                       </Input>
>                                               <Format>
> <MimeType>application/grass-raster-binary</MimeType>
>                                               </Format>
>                                       </Supported>
>                               </ComplexOutput>
>                       </Output>
>               </process_outputs>
>       </process_description>
>     </wps:process_descriptions>
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Gérald Fenoy
GEOLABS
Siège social :
Futur Building I
1280, avenue des Platanes
34970 Lattes
Tél. fixe : 04 67 53 67 37
Tél. portable : 06 70 08 25 39
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20091127/148c1bf5/attachment.html>
More information about the Zoo-discuss mailing list
