[ZOO-Discuss] ZOO Kernel 1.0 Release
Gérald Fenoy
gerald.fenoy at geolabs.fr
Fri Apr 16 08:25:34 PDT 2010
Hi Lucas,
it seems that your .htaccess file wasn't used by your Apache server.
Maybe you get AllowOverride None somewhere in your apache config ?
If you can''t use the RewriteRules, you should be able to test your ZOO Kernel installation using this url : http://127.0.0.1/cgi-bin/zoo_loader.cgi?ServiceProvider=&metapath=&Service=WPS&Request=GetCapabilities&Version=1.0.0
> when i try http://127.0.0.1/zoo/?Service=WPS&Request=GetCapabilities&Version=1.0.0
> the server return the page of my directory
> Index of /zoo
> [ICO] Name Last modified Size Description
> [DIR] Parent Directory -
> Apache/2.2.12 (Ubuntu) Server at 127.0.0.1 Port 80
> maybe the problem is in the .htaccess file when define the RewriteRule?
> It seems the RewriteRule is looking in the folders ../.. instead for
> my configuration it must search in /usr/lib/cgi-bin
Hope this help,
Djay
Just a ZOO Tribe Member
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100416/bb19f964/attachment.html>
More information about the Zoo-discuss
