[ZOO-Discuss] ZOO OnGoing Project : The Laurent Jégou Blog story
René-Luc D'Hont
rldhont at gmail.com
Sat Jan 9 01:15:44 PST 2010
Hi All,
This story is a very good point to demonstrate the ZOO capabilities!
Could we publish the ZOO OGR demo ?
René-Luc D'Hont
3Liz
Le 09/01/2010 02:28, Gérald Fenoy a écrit :
> Hi ZOO Tribe member,
> I have a story to share with you.
> Today, in the cold of France, *somebody* called me on phone and tell
> me that Lourent Jégou wrote an article on his blog [1] about using R
> with pyWPS.
> Laurent also mentioned that he did this choice, using pyWPS, cause ZOO
> Kernel is still unavailable (I use ZOO Kernel here, even if he spoke
> about "Zoo", in fact he means ZOO Kernel here). Oups, sorry for this
> point.
> So, *somebody* send me the link [2], unfortunately I wasn't in front
> of my computer so unable to read anything :). I asked him if the
> python code quoted in the article was available or not. As, he
> answered me it was, I told him that I call him back to tell him when
> the process was modified to be used from the ZOO Kernel.
> So I gone back on my computer and check this web page, fethcing the
> python code then copying the logic only included in the python file
> from the article (no metadata, as metadata and logic is separated in
> ZOO Kernel).
> Here "the logic code" I talk about was pointed in the full
> ServiceProvider, providing only one service called discretise :
> import rpy2.robjects as robjects
> import sys
> def discretise(main,inputs,outputs):
> # the following lines are need only because of
> # strange issue specific to R displaying msg :
> # Loading required package: class
> try:
> sys.stdout.close()
> except:
> pass
> # The logic code
> robjects.r('library(e1071)')
> robjects.r('library(classInt)')
> robjects.r('library(XML)')
> robjects.r('data(jenks71)')
> robjects.r('doc = xmlRoot(xmlTreeParse("%s"))' %
> inputs['donnees']['value'])
> xsa = robjects.r.xmlSApply
> jenksData = robjects.r('xmlSApply(doc, function(x)
> as.numeric(xmlSApply(x, xmlValue)))')
> ci = robjects.r.classIntervals
> tmp=int(inputs['nbClasses']['value'])
> out = str(ci(jenksData, n = tmp, style =
> inputs['methode']['value']))
> outputs["Result"]={"value": out,"dataType":"string"}
> return 3
> Then I copied the hellof.zcfg metadata file (the ZOO Configuration
> File for the sample Fortran ServiceProvider) into a new one called
> discretise.zcfg. I tested ... it and it works :)
> In fact it shuldn't work but I know that ZOO Kernel is really
> permissive when passing arguments to ServiceProvider function.... This
> explains why the hellof.zcfg file was enough to run the process...
> Nevertheless, in some sens, that let devs make their tests on their
> new service provider before putting them publicly available all over
> the web..
> So I correct a bit the ZOO Configuration file to get a realistic
> DescribeProcess.
> Finally, few minutes was requested to turn a simple pyWPS service into
> a service from a ServiceProvider Python Based to be run from the ZOO
> Kernel. I called back *somebody* :)
> I know it's not such an interesting example, but it let me think that
> the ZOO Kernel is a good tool to easily use an already existing code
> as a WPS service, even if it was not (a service) at the begining.
> Please, correct me if I'm wrong.
> So, even if here we duplicated a WPS service to create a new one,
> comparison between two solutions can be easily made for everyone
> reading this story. It contains also a view about what have to be done
> to integrate your own (Python here) code as a ServiceProvider
> providing WPS services through ZOO Kernel.
> Separation between metadata and services as a staring point,
> multi-language support in an embedded way to take control over service
> to provide.
> Parameters storeExecuteResponse was supported since the begining of
> ZOO Kernel development (cf. hello worlds from various embedded
> languages [3], [4] and [5]). It let users decide if they want to store
> the ExecuteResponse (on the current demonstration server we remove
> files quickly) to let him fetch/poll the statusLocation provided in
> the execute answer from its client application to show status of
> execution and be informed when the process was ended. It can be useful
> for applcication using a cache or something.
> [1] http://www.geotests.net/blog/
> [2]
> http://www.geotests.net/blog/article/mise-en-place-d-un-webservice-de-discretisation-en-utilisant-pywps-et-r
> [3]
> http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=hellof&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true
> <http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=hellof&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true>
> [4]
> http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true
> <http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=HelloWorldJava&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true>
> [5]
> http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=HelloPHP&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true
> <http://demo.zoo-project.org/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=HelloPHP&DataInputs=S=Your%20Name%20Here@datatype=string&storeExecuteResponse=true>
> *somebody* was abviously Nick !
> Hope to hear from you ZOO Tribe members,
> Djay
> Just a ZOO Monkey
> gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100109/132467db/attachment.html>
More information about the Zoo-discuss
