[ZOO-Discuss] ZOO Execute requests
Daisuke YOSHIDA
nro2dai at gmail.com
Sun May 16 17:40:02 PDT 2010
Gerald-san and Luca,
ZOO Execute request worked under my Mandriva2010.0 64bit and Ubuntu
10.4 32bit machines after adding PYTHONPATH in [env].
But there are still error messages as below,
[Mon May 17 09:22:39 2010] [error] [client 127.0.0.1] MAP => [Result]
[Mon May 17 09:22:39 2010] [error] [client 127.0.0.1] [DataType] => [string]
[Mon May 17 09:22:39 2010] [error] [client 127.0.0.1] [UOM] => [meter]
[Mon May 17 09:22:39 2010] [error] [client 127.0.0.1] [value] => [NULL]
But it is working at least.
I created an OVF virtual image (2.7GB) and linked the following page.
http://www.zoo-project.org/trac/wiki/ZooDocumentation/ZOOKernel/DebianLike_installation
It can be imported to VirtualBox or other virtual applications.
# I use VMware fusion.
Using virtual machine is good for beginners and workshop.
Best regards,
Daisuke Yoshida
On Sun, May 16, 2010 at 5:21 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2010/5/12 James Sewell <James.Sewell at ardec.com.au>:
>> Hey Nick,
>> Thanks for the reply. I am working on CentOS. I used the cgic from the
>> thirds directory (as mentioned DescribeProcess and GetCapabilities work fine
>> via HTTP).
> if you using python process maybe the problem is in your main.cfg,
> where you can try to add
> [env]
> PYTHONPATH=<YOUR_PYTHONPATH>
>> Cheers,
>> James Sewell
> cheers
> Luca
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss
