[ZOO-Discuss] Zoo Kernel + WCS
Angelos gcpp.kalxas at gmail.com
Thu May 20 04:08:07 PDT 2010
Hello Gerald,
Thank you very much for your instructions. I will
give it a try and report back my results.
Best regards,
Angelos
At 10:32 ðì 20/5/2010, Gérald Fenoy wrote:
>Hello Angelos,
>nice to hear that you use ZOO Kernel.
>I never used WCS server with ZOO but you should
>be able to use WCS Request as input for a ZOO
>Process. You would use a Reference for this
>input and set the xlink:href value as the url
>encoded version of your WCS Request. Something
>similar to the following, added in your GET
>Request DataInputs value should do the trick
>(note that you can also use the XML POST request which should be easier) :
><InputName>=Reference at xlink:href=<YouUrlEncodedRequest>
>Then in your ZOO Process you should get the
>string containing the WCS Response  in the
>"value" field of your input and can use it to feed your gdal processing.
>Hope it helps,
>best regards,
>Le 19 mai 2010 à 18:17, Angelos a écrit :
> > Hello everyone.
> > I would like to ask if someone has ever used
> the Zoo kernel with a WCS service.
> > I am trying to setup a scenario, in which a WCS service will provide
> > the imagery to Zoo, and a gdal processing service will consume this
> > image and post back results.
> > I have already a working setup of Zoo in Linux, built with Python,
> > PHP but not Java and JavaScript.
> > Thanks
> > Angelos
> > Zoo-discuss mailing list
> > Zoo-discuss at gisws.media.osaka-cu.ac.jp
> > http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>Djay
>Just a ZOO Tribe member
>gerald.fenoy at geolabs.fr
More information about the Zoo-discuss mailing list
