[ZOO-Discuss] ZOO Project WPS Validity report
René-Luc D'Hont rldhont at gmail.com
Mon Sep 20 03:41:39 PDT 2010
  Hi ZOOers,
I've published the Gérald text on my blog :
http://3liz.org/blog/rldhont/index.php/2010/09/20/344-zoo-project-wps-validity-report
And translated it in french :
http://3liz.org/blog/rldhont/index.php/2010/09/20/345-rapport-de-validite-du-zoo-project-vis-a-vis-de-la-norme-wps-de-l-ogc
René-Luc D'Hont
3Liz
Le 20/09/2010 10:22, Gérald Fenoy a écrit :
> Hi ZOOers,
> Several WPS related presentation at FOSS4G2010 including the
> one entitled "Compliance testing of Open Source Software for
> Web Processing Services" took place this year [1].
> The presentation above reported about some incorrect results about the
> ZOO-WPS implementation. So the ZOO-Tribe decided to provide a report
> based on the same techniques than the one used in above presentation
> and clarify of the ZOO Kernel valid XML responses using only Open
> Source software to run the tests.
> The results of our tests are available on wiki page on the official
> ZOO Project Trac system [2] where you can read the results we got when
> running the validity tests for each requests discussed during the
> conference. As we are in an Open Source community we also provided a
> tool [3] to run the tests on your own using a simple bash script
> (working also on GNU/Linux and MacOS X). This way you can ensure that
> tests made were appropriate. Based on this tool we created another
> script which provides periodically a web report available on the
> ZOO-Project web site [4].
> Contrary to what was said during in [1], all the tests made was
> successfully validated. Nevertheless, on the OGC external wiki [5], we
> noticed that the URLs used to run tests on the ZOO Kernel response
> validity was wrong so we have corrected it on this wiki page also.
> Finally the conclusion to this test are the following :
> a) ZOO Kernel provide XML document in responses to WPS request which
> are all valid,
> b) ZOO Kernel support all the Execute request type
> I hope you can take few minutes of your busy time to read the report
> and check by yourself that everything is working fine with the ZOO
> Kernel and maybe even more in the form of a a generic way to test our
> WPS implementation responses validity which will be useful for future
> testing.
> Best regards,
> [1] http://2010.foss4g.org/presentations_show.php?id=3604
> [2] http://www.zoo-project.org/trac/wiki/ZOOWPSImplementationReport
> [3]
> http://www.zoo-project.org/trac/attachment/wiki/ZOOWPSImplementationReport/testXmlValidation.sh
> [4] http://zoo-project.org/ZOODEMOREP/demoReport1.html
> [5]
> http://external.opengeospatial.org/twiki_public/bin/view/WPS/ComplianceTestingResults2010
> Gérald Fenoy
> ZOO PSC Chair
> gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100920/5616bf72/attachment.html>
More information about the Zoo-discuss mailing list
