[ZOO-Discuss] GIS GRASS ZOO integration
Soeren Gebbert
soerengebbert at googlemail.com
Wed Sep 29 06:37:09 PDT 2010
Hello Eugenio,
2010/9/27 Eugenio Realini <eugenio.realini at gmail.com>:
> HI Soeren,
> 2010/9/24 Soeren Gebbert <soerengebbert at googlemail.com>:
>> Back to the problem: the Python WPS interface was generated using PyXB
>> version 1.1.1, so this may be the source of the error. Can you please
>> try PyXB 1.1.1?
> Still not working also with PyXB 1.1.1
Well this is strange ... .
> Since the error is in _ows.py, that I've seen it was generated by
> PyXB, could I try to generate it again from scratch?
Yes you can try to generate the WPS.1.0.0 python modules with PyXB
1.1.2 by yourself:
mkdir WPS_1_0_0
cd WPS_1_0_0/
pyxbgen -u http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd -m OGC_WPS_1_0_0
touch __init__.py
Then replace the WPS_1_0_0 dir with the new one. Make sure your gdal
installation was compiled with C++ Xerxes support, otherwise the
logfile of the ZOOGrassModuleStarter located at /tmp/logfile.txt will
contain these lines:
<INFO>
ERROR 1: Unable to create Xerces C++ based GML reader, Xerces support
not configured into GDAL/OGR.
ERROR 1: File /tmp/tmp8s38Ab/input_0 appears to be GML but the GML reader can't
be instantiated, likely because Xerces support wasn't
configured in.
ERROR: Unable to open data source </tmp/tmp8s38Ab/input_0>
</INFO>
<ERROR>
GDLA error while import. Unable to create input location from input
</ERROR>
Which happened to me right now, because my gdal installation was
compiled without Xerxes at work. :/
I hope you are able to run it. Please use the latest svn version of
the wps-grass-bridge, i fixed some bugs.
Best regards
Soeren
> Thanks
> Ege
More information about the Zoo-discuss
