[ZOO-Discuss] Error when running GRASS processes
Pierre Roudier pierre.roudier at gmail.com
Thu Apr 28 21:19:05 PDT 2011
Gerald, Soeren,
Many thanks for your answers.
I do make sure I'm running the latest svn updates of both ZOO and
wps-grass-bridge (I like the sound of a compiling machine in the
morning and it keeps my coffee cup warm ;).
Unfortunately, the apache log is not really verbose, only sasying that
the v_voronoi module is not found:
ImportError: No module named v_voronoi
> make sure that the wps-grass-bridge as well as the zcfg and python
> services are located in the process directory.
I'm not too sure what you call process directory. Here is the content
of my /usr/lib/cgi-bin/
gms  HelloPy.zcfg  main.cfg  pywps.cgi  pywps_start  test_service.py
v_delaunay.zcfg  v_voronoi.zcfg  ZOOGrassModuleStarter.py
zoo_loader.cgi
the gms directory contains the following files:
ErrorHandler.py  GrassModuleStarter.py  GrassSettings.py  __init__.py
ParameterParser.py  ProcessLogging.py  Testing
I guess this is probably where I get it wrong, as the HelloWorld
module, independant from wps-grass-bridge, is working.
> Since today there are several XML execute requests and a simple python
> script available in wps-grass-bridge to test the WPS server:
> http://code.google.com/p/wps-grass-bridge/source/browse/#svn%2Ftrunk%2FTesting%2FPython
Yes, I noticed it - is it supposed to be launched from my server's shell?
Your help, and the efforts you are putting on open-source software,
is greatly appreciated.
Best,
Pierre
> Best regards
> Soeren
> 2011/4/28 Pierre Roudier <pierre.roudier at gmail.com>:
>> Dear zoo-keepers,
>> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
>> I've added two GRASS  processes to my /usr/lib/cgi-bin:
>> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
>> HelloPy.zcfg
>> v_delaunay.zcfg
>> v_voronoi.zcfg
>> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
>> to try to make a Voronoi tesselation or a Delaunay triangulation of a
>> dummy points shapefile. In both cases, I got the following error when
>> running the process:
>> <?xml version="1.0" encoding="utf-8"?>
>> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> xml:lang="en-US" version="1.1.0">
>>  <ows:Exception exceptionCode="NoApplicableCode">
>>    <ows:ExceptionText>Python module v_delaunay cannot be loaded.
>> </ows:ExceptionText>
>>  </ows:Exception>
>> </ows:ExceptionReport>
>> Any suggestion?
>> Cheers,
>> Pierre
>> Scientist
>> Landcare Research, New Zealand
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Scientist
More information about the Zoo-discuss mailing list
