[ZOO-Discuss] Boundary ZOO Service
Gérald Fenoy
gerald.fenoy at geolabs.fr
Fri Feb 11 07:35:14 PST 2011
Hello Quang,
as it seems you don't get nor xml2-config nor gdal-config, let's first
try to install those tools using the following apt-get command :
sudo apt-get install libxml2-dev libgdal1-dev
Then rerun the same commands as before should do the trick.
Note that, I missed it at the first time, it should be --cflags rather
than --clfags for xml2-config call in the CFLAGS definition. All
the rest sounds good.
Hope this help,
Best,
Le 11 févr. 2011 à 16:08, truongxuan quang a écrit :
> Dear Gérald
> Many thanks for your support.
> I have followed your commands, the 1st and 2nd are fine,
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# export CFLAGS="`gdal-config --cflags` `xml2-config --clfags` -I../../zoo-kernel/"
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# export LDFLAGS="`gdal-config --libs` `xml2-config --libs` ../../zoo-kernel/service_internal.o"
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
> I got inform bellow
> gcc: Usage:: No such file or directory
> gcc: xml2-config: No such file or directory
> gcc: [OPTION]: No such file or directory
> gcc: Known: No such file or directory
> gcc: values: No such file or directory
> gcc: for: No such file or directory
> gcc: OPTION: No such file or directory
> gcc: are:: No such file or directory
> gcc: change: No such file or directory
> gcc: libxml: No such file or directory
> gcc: prefix: No such file or directory
> gcc: [default: No such file or directory
> gcc: /usr]: No such file or directory
> gcc: exec: No such file or directory
> gcc: print: No such file or directory
> gcc: library: No such file or directory
> gcc: linking: No such file or directory
> gcc: information: No such file or directory
> gcc: add: No such file or directory
> gcc: to: No such file or directory
> gcc: static: No such file or directory
> gcc: pre-processor: No such file or directory
> gcc: and: No such file or directory
> gcc: compiler: No such file or directory
> gcc: flags: No such file or directory
> gcc: module: No such file or directory
> gcc: support: No such file or directory
> gcc: enabled: No such file or directory
> gcc: display: No such file or directory
> gcc: this: No such file or directory
> gcc: help: No such file or directory
> gcc: exit: No such file or directory
> gcc: output: No such file or directory
> gcc: version: No such file or directory
> I checked, there are not exist : xml2-config and gdal-config in /usr/local/bin for example, I dont know where is the place to configure the libxml and gdal in this case, I used OSGeo/live.
> Thanks
> T.X.Quang
> From: Gérald Fenoy <gerald.fenoy at geolabs.fr>
> To: truongxuan quang <truongxuanquang at yahoo.com>
> Cc: zoo-discuss at gisws.media.osaka-cu.ac.jp
> Sent: Fri, February 11, 2011 1:10:51 PM
> Subject: Re: [ZOO-Discuss] Boundary ZOO Service
> Dear Quang,
> Please, try the following command :
> It should work this way.
> I noticed that you tried to set values to CFLAGS and LDFLAGS on one command
> line. You have to first define the env variables then use them.
> You asked about service_internal.o, it is present in your LDFLAGS so should be
> found. This file is located in the zoo-kernel directory.
> Hope this help,
> Best,
> Le 11 févr. 2011 à 12:02, truongxuan quang a écrit :
>> Hello Gérald
>> Thank you for your email, and I also sorry for replying late.
>> Bellow is my values set for both CFLAGS and LDFLAGS, because I am not familiar with Linux that why I have stuck in this section.
>> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++ $CFLAGS=`gdal-config --cflags` `xml2-config --clfags` -I../../zoo-kernel/ -shared -fpic -o cgi-env/ServicesProvider.zo ./service.c $LDFLAGS=`gdal-config --libs` `xml2-config --libs` ../../zoo-kernel/service_internal.o
>> I got
>> g++: =-I/usr/include/gdal: No such file or directory
>> g++: Usage:: No such file or directory
>> g++: xml2-config: No such file or directory
>> g++: [OPTION]: No such file or directory
>> g++: Known: No such file or directory
>> g++: values: No such file or directory
>> g++: for: No such file or directory
>> g++: OPTION: No such file or directory
>> g++: are:: No such file or directory
>> g++: change: No such file or directory
>> g++: libxml: No such file or directory
>> g++: prefix: No such file or directory
>> g++: [default: No such file or directory
>> g++: /usr]: No such file or directory
>> g++: exec: No such file or directory
>> g++: print: No such file or directory
>> g++: library: No such file or directory
>> g++: linking: No such file or directory
>> g++: information: No such file or directory
>> g++: add: No such file or directory
>> g++: to: No such file or directory
>> g++: static: No such file or directory
>> g++: pre-processor: No such file or directory
>> g++: and: No such file or directory
>> g++: compiler: No such file or directory
>> g++: flags: No such file or directory
>> g++: module: No such file or directory
>> g++: support: No such file or directory
>> g++: enabled: No such file or directory
>> g++: display: No such file or directory
>> g++: this: No such file or directory
>> g++: help: No such file or directory
>> g++: exit: No such file or directory
>> g++: output: No such file or directory
>> g++: version: No such file or directory
>> g++: =-L/usr/lib: No such file or directory
>> g++: ../../zoo-kernel/service_internal.o: No such file or directory
>> Usage: g++ [options] file...
>> One more question is how to get service_internal.o file ?
>> Thank you
>> Quang
Gérald Fenoy
ZOO-PSC Chair
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110211/097968da/attachment.html>
More information about the Zoo-discuss
