[ZOO-Discuss] Boundary ZOO Service
truongxuan quang truongxuanquang at yahoo.com
Fri Feb 11 09:33:00 PST 2011
Dear Gérald
Thanks!  exactly I was missing CGAL so after install, it look better, I sent you
the result what I have got.
root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++ $CFLAGS
-shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
g++: ../../zoo-kernel/service_internal.o: No such file or directory
./service.c: In function ‘void* createGeometryFromGML(maps*, char*)’:
./service.c:75: warning: deprecated conversion from string constant to ‘char*’
./service.c: In function ‘int Delaunay(maps*&, maps*&, maps*&)’:
./service.c:122: warning: deprecated conversion from string constant to ‘char*’
./service.c:142: warning: deprecated conversion from string constant to ‘char*’
./service.c:181: warning: deprecated conversion from string constant to ‘char*’
./service.c:183: warning: deprecated conversion from string constant to ‘char*’
./service.c:187: warning: deprecated conversion from string constant to ‘char*’
./service.c:230: warning: deprecated conversion from string constant to ‘char*’
./service.c:265: error: conversion from
‘CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
 > >, CGAL::Triangulation_ds_vertex_base_2<void> >,
CGAL::Triangulation_ds_face_base_2<void> > >’ to non-scalar type
‘Vertex_circulator’ requested
./service.c:379: warning: deprecated conversion from string constant to ‘char*’
./service.c:384: warning: format ‘%d’ expects type ‘int’, but argument 4 has
type ‘__off_t’
./service.c: In function ‘int Voronoi(maps*&, maps*&, maps*&)’:
./service.c:417: warning: deprecated conversion from string constant to ‘char*’
./service.c:437: warning: deprecated conversion from string constant to ‘char*’
./service.c:474: warning: deprecated conversion from string constant to ‘char*’
./service.c:476: warning: deprecated conversion from string constant to ‘char*’
./service.c:480: warning: deprecated conversion from string constant to ‘char*’
./service.c:523: warning: deprecated conversion from string constant to ‘char*’
./service.c:595: warning: deprecated conversion from string constant to ‘char*’
Thank you and waiting for last help
Best,
T.X.Quang
To: truongxuan quang <truongxuanquang at yahoo.com>
Cc: zoo-discuss <zoo-discuss at gisws.media.osaka-cu.ac.jp>
Sent: Fri, February 11, 2011 5:36:32 PM
Subject: Re: [ZOO-Discuss] Boundary ZOO Service
Dear Quang,
scuse me, at the beginning you used g++ so I didn't noticed that after you
changed for
g++. It seems you need to use g++ in your case.
Your service provider is depending on CGAL. Are you sure you get it installed on
your
OSGeoLiveDVD platform ?
If not, you probably would use the following command to install CGAL library
and
header files (the -dev package in the Debian world):
  sudo apt-install search libcgal-dev
Maybe your service provider doesn't need GDAL library, in such case, please,
remove
the include lines mentioning the CGAL directory.
Hope it help,
Best,
Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
>Thank you for help,  I am  sorry!!! but I need you help again because it still
>getting errors  after run the 3rd command
>root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS
>gcc: ../../zoo-kernel/service_internal.o: No such file or directory
>./service.c:1:64: error: CGAL/Exact_predicates_inexact_constructions_kernel.h:
>./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No such
>file or directory
>./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or
>directory
>./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No such
>file or directory
>./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or
>directory
>./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or
>directory
>./service.c:8:19: error: fstream: No such file or directory
>In file included from /usr/include/gdal/ogr_geometry.h:35,
>                 from /usr/include/gdal/ogr_feature.h:33,
>                 from /usr/include/gdal/ogrsf_frmts.h:33,
>                 from ./service.c:12:
>/usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before
>‘OGR_SRSNode’
>/usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before
>‘OGRSpatialReference’
>/usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before
>‘OGRCoordinateTransformation’
>/usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before ‘*’
>token
>In file included from /usr/include/gdal/ogr_feature.h:33,
>/usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>‘__attribute__’ before ‘OGRRawPoint’
>/usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before
>‘OGRGeometry’
>/usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before
>‘OGRPoint’
>/usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before
>‘OGRCurve’
>/usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before
>‘OGRLineString’
>/usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before
>‘OGRLinearRing’
>/usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before
>‘OGRSurface’
>/usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before
>‘OGRPolygon’
>/usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before
>‘OGRGeometryCollection’
>/usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before
>‘OGRMultiPolygon’
>/usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before
>‘OGRMultiPoint’
>/usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before
>‘OGRMultiLineString’
>/usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before
>‘OGRGeometryFactory’
>In file included from /usr/include/gdal/ogr_feature.h:34,
>/usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>‘__attribute__’ before ‘OGRFeature’
>/usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before
>‘OGRStyleTable’
>/usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>or ‘__attribute__’ before ‘OGRStyleTool’
>/usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before
>‘OGRStyleMgr’
>/usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before
>‘OGRStyleTool’
>/usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before
>‘OGRStylePen’
>/usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before
>‘OGRStyleBrush’
>/usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before
>‘OGRStyleSymbol’
>/usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no type
>or storage class
>/usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before
>‘OGRStyleLabel’
>In file included from /usr/include/gdal/ogrsf_frmts.h:33,
>/usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before
>‘OGRFieldDefn’
>/usr/include/gdal/ogr_feature.h:113: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before
>‘OGRFeatureDefn’
>/usr/include/gdal/ogr_feature.h:159: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before
>‘OGRFeature’
>/usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>‘__attribute__’ before ‘OGRLayer’
>/usr/include/gdal/ogr_feature.h:298: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before
>‘OGRFeatureQuery’
>In file included from ./service.c:12:
>/usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>‘__attribute__’ before ‘OGRLayerAttrIndex’
>/usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>‘__attribute__’ before ‘OGRSFDriver’
>/usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before
‘OGRLayer’
>/usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before
>‘OGRDataSource’
>/usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before
>‘OGRSFDriver’
>/usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type or
>storage class
>/usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before
>‘OGRSFDriverRegistrar’
>./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>‘:’ token
>./service.c:33: error: expected identifier or ‘(’ before string constant
>Thanks
>T.X.Quang
Never miss an email again!
>Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
Gérald Fenoy
ZOO-PSC Chair
gerald.fenoy at geolabs.fr
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110211/1c643e7d/attachment.html>
More information about the Zoo-discuss mailing list
