[ZOO-Discuss] Boundary ZOO Service
truongxuan quang truongxuanquang at yahoo.com
Mon Feb 14 08:20:00 PST 2011
Dear Gérald
Thank for all you help...I will move to the ogr/base-vect-ops first and if I
have time I will look back for CGAL, because CGAL's library attracted me.
I will focus in next section if I face any doubts please help me again.
Thank you very much
Quang
To: truongxuan quang <truongxuanquang at yahoo.com>
Cc: zoo-discuss <zoo-discuss at gisws.media.osaka-cu.ac.jp>
Sent: Mon, February 14, 2011 4:43:55 PM
Subject: Re: [ZOO-Discuss] Boundary ZOO Service
Dear Quang,
as I think you was trying the Workshop material, you shouldn't download any
source code
from the SVN tree ... You should create an empty file and fill it with the
content provided in
the workshop material.
CGAL service seems to get trouble, we tried it some *years* ago with probably an
older
CGAL version ... not sure.
Probably switching to the ogr/base-vect-ops, which is the service used in the
workshop
material would be easier.
Hope to hear from you,
Best,
Le 14 févr. 2011 à 15:32, truongxuan quang a écrit :
>Dear Gérald
>Thank you very much as you said, I have changed
>/home/user/zoows/sources/zoo-services/ws_sp/service.c file line 265  from
>Vertex_circulator vc = .... to Vertex_circulator* vc = .... and the feedback
>comment as you can see below. Gérald, I just remember when I created ws_sp main
>Services Provider directory in the existing zoo-services by
>mkdir -p /home/user/zoows/sources/zoo-services/ws_sp/cgi-env
>There was not include service.c inside ws_sp I had copied service.c
>from http://zoo-project.org/trac/browser/branches/branch-1.2/zoo-services/cgal/service.c it
> is right in this case ?
>root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++ $CFLAGS
>-shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
>./service.c: In function ‘void* createGeometryFromGML(maps*, char*)’:
>./service.c:75: warning: deprecated conversion from string constant to ‘char*’
>./service.c: In function ‘int Delaunay(maps*&, maps*&, maps*&)’:
>./service.c:122: warning: deprecated conversion from string constant to ‘char*’
>./service.c:142: warning: deprecated conversion from string constant to ‘char*’
>./service.c:181: warning: deprecated conversion from string constant to ‘char*’
>./service.c:183: warning: deprecated conversion from string constant to ‘char*’
>./service.c:187: warning: deprecated conversion from string constant to ‘char*’
>./service.c:230: warning: deprecated conversion from string constant to ‘char*’
>./service.c:265: error: cannot convert
>‘CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >, CGAL::Triangulation_ds_vertex_base_2<void> >,
>CGAL::Triangulation_ds_face_base_2<void> > >’ to ‘Vertex_circulator*’ in
>initialization
>./service.c:268: error: ‘class
>CGAL::Triangulation_ds_vertex_circulator_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>CGAL::Triangulation_ds_face_base_2<void> > >’ has no member named ‘point’
>./service.c:379: warning: deprecated conversion from string constant to ‘char*’
>./service.c:384: warning: format ‘%d’ expects type ‘int’, but argument 4 has
>type ‘__off_t’
>./service.c: In function ‘int Voronoi(maps*&, maps*&, maps*&)’:
>./service.c:417: warning: deprecated conversion from string constant to ‘char*’
>./service.c:437: warning: deprecated conversion from string constant to ‘char*’
>./service.c:474: warning: deprecated conversion from string constant to ‘char*’
>./service.c:476: warning: deprecated conversion from string constant to ‘char*’
>./service.c:480: warning: deprecated conversion from string constant to ‘char*’
>./service.c:523: warning: deprecated conversion from string constant to ‘char*’
>./service.c:595: warning: deprecated conversion from string constant to ‘char*’
>Thanks
>Quang
>Sent: Mon, February 14, 2011 1:06:16 PM
>Dear Quang,
>thanks for your investigations.
>I suppose that on your line 265 you get the following :
>Please, try to use this :
>Hope this help and you will give us feedback,
>best
>Le 14 févr. 2011 à 12:50, truongxuan quang a écrit :
>Dear Gérald
>>Thank you for your help. I have checked again
>>../../zoo-kernel/service_internal.o, it missed service_internal.o file, I had
>>copy from zoows.tar.bz2 I already avoid previous error "No such file or
>>directory". But there is still error 265 in my command,  Could you please have a
>>look for responsive inform bellow
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
>>./service.c:265: error: conversion from
>>CGAL::Triangulation_ds_face_base_2<void> > >’ to non-scalar type
>>‘Vertex_circulator’ requested
‘char*’
>>type ‘__off_t’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
‘char*’
>> in this directory  /usr/include/CGAL there is not including
>>Triangulation_ds_vertex_circulator_2.h file as 265 error said.
>>please help me to fix the error.
>>Thank you very much and have a nice day
>>T.X.Quang
>>Sent: Fri, February 11, 2011 7:34:55 PM
>>Quang,
>>I noticed something a bit strange in the error messages you shown to me.
>>g++ is not able to find ../../zoo-kernel/service_internal.o from your ws_sp
>>directory.
>>Can you ensure that when you do "ls ../../zoo-kernel/service_internal.o" it
>>gives you
>>the file name rather than a message explaining that there is no file with that
>>name.
>>If you don't get the file, then you will probably have to compile zoo-kernel in
>>the
>>../../zoo-kernel directory.
>>Once you get the compiled ZOO-Kernel you should solve one issue. Then there
>>is still the error about the line 265 of the service.c file. Let see if we can
>>go to this
>>last step.
>>Hope it helps,
>>Best
>>Le 11 févr. 2011 à 18:33, truongxuan quang a écrit :
>>Dear Gérald
>>>Thanks!  exactly I was missing CGAL so after install, it look better, I sent you
>>>the result what I have got.
>>>g++: ../../zoo-kernel/service_internal.o: No such file or directory
‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>>>type ‘__off_t’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>‘char*’
>>>Thank you and waiting for last help
>>>Best,
>>>T.X.Quang
>>>Sent: Fri, February 11, 2011 5:36:32 PM
>>>Dear Quang,
>>>scuse me, at the beginning you used g++ so I didn't noticed that after you
>>>changed for
>>>g++. It seems you need to use g++ in your case.
>>>Your service provider is depending on CGAL. Are you sure you get it installed on
>>>your
>>>OSGeoLiveDVD platform ?
>>>If not, you probably would use the following command to install CGAL library
>>>and
>>>header files (the -dev package in the Debian world):
>>>  sudo apt-install search libcgal-dev
>>>Maybe your service provider doesn't need GDAL library, in such case, please,
>>>remove
>>>the include lines mentioning the CGAL directory.
>>>Hope it help,
>>>Best,
>>>Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
>>>>Thank you for help,  I am  sorry!!! but I need you help again because it still
>>>>getting errors  after run the 3rd command
>>>>root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS
>>>>gcc: ../../zoo-kernel/service_internal.o: No such file or directory
>>>>./service.c:1:64: error: CGAL/Exact_predicates_inexact_constructions_kernel.h:
>>>>./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No such
>>>>file or directory
>>>>./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or
>>>>directory
>>>>./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No such
>>>>file or directory
>>>>./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or
>>>>directory
>>>>./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or
>>>>directory
>>>>./service.c:8:19: error: fstream: No such file or directory
>>>>In file included from /usr/include/gdal/ogr_geometry.h:35,
>>>>                 from /usr/include/gdal/ogr_feature.h:33,
>>>>                 from /usr/include/gdal/ogrsf_frmts.h:33,
>>>>                 from ./service.c:12:
>>>>/usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before
>>>>‘OGR_SRSNode’
>>>>/usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before
>>>>‘OGRSpatialReference’
>>>>/usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before
>>>>‘OGRCoordinateTransformation’
>>>>/usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before ‘*’
>>>>token
>>>>In file included from /usr/include/gdal/ogr_feature.h:33,
>>>>/usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>>‘__attribute__’ before ‘OGRRawPoint’
>>>>/usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before
>>>>‘OGRGeometry’
>>>>/usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before
>>>>‘OGRPoint’
>>>>/usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before
>>>>‘OGRCurve’
>>>>/usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before
>>>>‘OGRLineString’
>>>>/usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before
>>>>‘OGRLinearRing’
>>>>/usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before
>>>>‘OGRSurface’
>>>>/usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before
>>>>‘OGRPolygon’
>>>>/usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before
>>>>‘OGRGeometryCollection’
>>>>/usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before
>>>>‘OGRMultiPolygon’
>>>>/usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before
>>>>‘OGRMultiPoint’
>>>>/usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before
>>>>‘OGRMultiLineString’
>>>>/usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before
>>>>‘OGRGeometryFactory’
>>>>In file included from /usr/include/gdal/ogr_feature.h:34,
>>>>/usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>>‘__attribute__’ before ‘OGRFeature’
>>>>/usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleTable’
>>>>/usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>>>or ‘__attribute__’ before ‘OGRStyleTool’
>>>>/usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleMgr’
>>>>/usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleTool’
>>>>/usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStylePen’
>>>>/usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleBrush’
>>>>/usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleSymbol’
>>>>/usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no type
>>>>or storage class
>>>>/usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before
>>>>‘OGRStyleLabel’
>>>>In file included from /usr/include/gdal/ogrsf_frmts.h:33,
>>>>/usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before
>>>>‘OGRFieldDefn’
>>>>/usr/include/gdal/ogr_feature.h:113: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before
>>>>‘OGRFeatureDefn’
>>>>/usr/include/gdal/ogr_feature.h:159: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before
>>>>‘OGRFeature’
>>>>/usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>>‘__attribute__’ before ‘OGRLayer’
>>>>/usr/include/gdal/ogr_feature.h:298: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before
>>>>‘OGRFeatureQuery’
>>>>In file included from ./service.c:12:
>>>>/usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>>‘__attribute__’ before ‘OGRLayerAttrIndex’
>>>>/usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
>>>>‘__attribute__’ before ‘OGRSFDriver’
>>>>/usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before
>>>‘OGRLayer’
>>>>/usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before
>>>>‘OGRDataSource’
>>>>/usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before
>>>>‘OGRSFDriver’
>>>>/usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type or
>>>>storage class
>>>>/usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before
>>>>‘OGRSFDriverRegistrar’
>>>>./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>>‘:’ token
>>>>./service.c:33: error: expected identifier or ‘(’ before string constant
>>>>Thanks
>>>>T.X.Quang
Never miss an email again!
>>>>Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
>>>Gérald Fenoy
>>>ZOO-PSC Chair
>>>gerald.fenoy at geolabs.fr
>>Gérald Fenoy
>>ZOO-PSC Chair
>Gérald Fenoy
>ZOO-PSC Chair
Expecting? Get great news right away with email Auto-Check.
>Try the Yahoo! Mail Beta.
Gérald Fenoy
ZOO-PSC Chair
____________________________________________________________________________________
Get your own web address.
Have a HUGE year through Yahoo! Small Business.
http://smallbusiness.yahoo.com/domains/?p=BESTDEAL
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110214/67cf0652/attachment.html>
More information about the Zoo-discuss mailing list
