[ZOO-Discuss] [ZOO Project Trac] #3: Filling optional default values issue with GIS GRASS integration
ZOO Project Trac
zoo-dev at cartography.st
Fri Jan 7 16:40:21 PST 2011
Reporter: soeren | Owner:
Type: defect | Status: closed
Priority: major | Component: zoo-kernel
Version: 1.0 | Resolution: fixed
Keywords: optional values |
Changes (by djay):
* status: new => closed
* resolution: => fixed
Comment:
Since [changeset:63 Revision #63], the ZOO-Kernel does not fill the
default value map of the inputs maps in the following case: it is not
provided in the request !DataInputs and there is no default value set in
the zcfg file for this input.
Nevertheless, it still provides other format informations, which means for
intance for !LitteralData dataType information and potential UOM. This
way, from any programming language you are able to test if the value was
provided (or default valued) or not. For instance from Python using
{{{"value" in inputs["grass_band_number"]}}} you can check if the value
was provided in the request or not.
I think this is similar to what you propose as solution 2. Indeed, even if
it does not provide specific programming language null value in inputs the
value is well not defined in any programming languages.
For ComplexData it would work the same.
For outputs maps, the NULL value is still set in maps.
Please, feel free to reopen this ticket if anything goes wrong with
default value setting.
Ticket URL: <http://svn.zoo-project.org/trac/ticket/3#comment:1>
ZOO Project Trac <http://www.zoo-project.org/>
Open WPS Platform
More information about the Zoo-discuss
