[ZOO-Discuss] Multiple supported mime type defintions
Gérald Fenoy
gerald.fenoy at geolabs.fr
Sun Jan 30 02:48:58 PST 2011
Hi list,
I noticed that I didn't inform you that this issue was solved.
Now it's done :)
Best,
Le 16 nov. 2010 à 13:28, Soeren Gebbert a écrit :
> Hi,
> many thanks for the info.
> Using yaml will indeed make many thinks much easier .... i eagerly
> waiting for it!
> Cheers
> Soeren
> 2010/11/16 rldhont <rldhont at gmail.com>:
>> Hi Soeren,
>> It's a Bug! I already report it to Gérald, but the new config file based
>> on YAML, I think, correct it.
>> René-Luc D'Hont
>> P.S: we need a roadmap
>> Le 16/11/2010 13:13, Soeren Gebbert a écrit :
>>> Hello,
>>> does anybody know how to specify multiple<supported> formats in a .zcfg file?
>>> I have a lot GRASS GIS processes which support many input and output
>>> data formats.
>>> I thought defining multiple "supported" tags will solve this, but the
>>> generated XML process description has only one format listed?
>>> Any help is appreciated.
>>> This is a part of my .zcfg file:
>>> [input]
>>> Title = Data source for OGR access
>>> Abstract =
>>> minOccurs = 1
>>> maxOccurs = 1
>>> <ComplexData>
>>> <Default>
>>> mimeType = text/xml
>>> encoding = UTF-8
>>> schema = http://schemas.opengis.net/gml/2.1.2/feature.xsd
>>> </Default>
>>> <Supported>
>>> mimeType = text/xml
>>> encoding = UTF-8
>>> </Supported>
>>> <Supported>
>>> mimeType = text/xml
>>> encoding = UTF-8
>>> schema = http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd
>>> </Supported>
>>> <Supported>
>>> mimeType = application/dgn
>>> </Supported>
>>> <Supported>
>>> mimeType = application/shp
>>> </Supported>
>>> <Supported>
>>> mimeType = application/x-zipped-shp
>>> </Supported>
>>> </ComplexData>
>>> Best regards
>>> Soeren
>>> Zoo-discuss mailing list
>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Djay
ZOO-PSC Chair
More information about the Zoo-discuss
