[ZOO-Discuss] ZOO testing
Gérald Fenoy gerald.fenoy at geolabs.fr
Tue Mar 22 02:21:49 PDT 2011
Hello James,
many thanks for your feedbacks.
The XML Post request should work, it was supposed to be supported for years now but we didn't used for a while now. Maybe there is something in the way we parse the XML file I will take a deeper look at it right now and will keep you informed asap about what happened.
To support the QGIS WPS Client we modify a bit the way we parse the incoming POST request so maybe we introduce some new issue here. Anyway the form is a bit old and use a request parameter which is not valid as wps POST request should arrive with body content rather than using any request parameter. I'm not sure this form can be still used as-is without adding some javascript to post request in the right way.
Be back to you soon,
best,
Le 22 mars 2011 à 06:38, James.Sewell at lisasoft.com a écrit :
> Hello again,
> Does ZOO support XML POST requests (as opposed to KVP requests) to a WFS server? Something like the example given in the second post inthis thread. I have not been able to get it to work in my installation or in your demo installation, although I presume it must be supported. An example or a link to an example would be nice if possible!
> Also I believe that the demo located at http://www.zoo-project.org/trac/wiki/ZOOWPSImplementationReport might be broken. If I take the first Execute request and paste it into the form located at http://zoo-project.org/test_services.html then I get the following error:
>                 Unenderstood <request> value. Please check that it was set to GetCapabilities, DescribeProcess or Execute.
> Cheers,
> James Sewell
> Developer
> LISAsoft
> Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
> Level 9, 601 Bourke St, Melbourne Vic 3000
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Gérald Fenoy
GEOLABS
Siège social :
Futur Building I
1280, avenue des Platanes
34970 Lattes
Tél. fixe : +33 (0) 4 67 43 09 95
Tél. portable : +33 (0) 6 70 08 25 39
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110322/b57e616c/attachment.html>
More information about the Zoo-discuss mailing list
