[ZOO-Discuss] Execute request returns SIGSEGV message from the zoo kernel for Python
Gérald Fenoy
gerald.fenoy at geolabs.fr
Tue Mar 22 09:57:34 PDT 2011
Armin,
it seems that the issue is lightly different from the first one.
Maybe it comes from the cURL version you are using. To confirm that assumption, can you
try to add -DTIGER to the CFLAGS in your Makefile to then clean and recompile the
ZOO-Kernel ?
If it works this mean that we have to look deeply in the cURL version installed on the target
and check which one cause trouble and which one not. Or force installer to use a specific cURL
version.
I'm currently use ZOO-Kernels linked against 7.19.6 (on GNU/Linux) and 7.19.7 (on MacOS X)
without issue.
Something sounds odd to me in your last backtrace. Indeed it seems that the ZOO-Kernel
is trying to download something but in your example it should not. Can you give me the exact
command line you were using for getting such a result ?
Hope to hear from you,
Best,
Le 22 mars 2011 à 17:29, Armin Burger a écrit :
> Gerald
> I followed all the steps and still get the segfault message
> <ows:Exception exceptionCode="InternalError">
> <ows:ExceptionText>ZOO Kernel failed to process your request
> receiving signal 11 = SIGSEGV</ows:ExceptionText>
> </ows:Exception>
> If I compile with USE_DBG the it writes out a core dump file,
> analyzing it gives the message
> Core was generated by `./zoo_loader.cgi
> request=Execute&service=WPS&version=1.0.0&Identifier=HelloPy&D'.
> Program terminated with signal 11, Segmentation fault.
> #0 0xb7f317ea in curl_formadd () from /usr/lib/libcurl.so.3
> (gdb) bt
> #1 0xb7f41018 in curl_slist_free_all () from /usr/lib/libcurl.so.3
> #2 0xb7f4cf67 in curl_easy_setopt () from /usr/lib/libcurl.so.3
> #3 0x08059aaf in InternetOpen ()
> #4 0x0804d4f0 in runRequest (request_inputs=0x806e988) at
> zoo_service_loader.c:708
> #5 0x0804b201 in cgiMain () at zoo_loader.c:264
> #6 0x08060414 in main (argc=2, argv=0xbf88d584) at cgic.c:303
> armin
> On Tue, Mar 22, 2011 at 4:39 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>> Hi Armin,
>> I did the following steps and everything goes right.
>> 1) Download the SVN source tree
>> 2) compile cgic206 from the SVN source tree thirds directory
>> 3) go into zoo-kernel directory and run autoconf
>> 4) run : ./configure --with-python
>> 5) create a directory zoo-dist
>> 6) copy zoo_loader.cgi and main.cfg in zoo-dist
>> 7) copy zoo-services/hello-py/test_service.py and
>> zoo-services/hello-py/cgi-env/HelloPy.zcfg in zoo-dist
>> 8) from the zoo-dist directory, I run the following :
>> ./zoo_loader.cgi
>> "request=Execute&service=WPS&version=1.0.0&Identifier=HelloPy&DataInputs=a=Demo"
>> I get the hello world message included in the ExecuteResponse.
>> Please can you try to reproduce the steps above on your platform and
>> let me know if the error still occurs ?
>> Best
>> Le 22 mars 2011 à 14:16, Armin Burger a écrit :
>> Nick
>> I tried the SVN from today, still a segfault. I tried using GDB and
>> the only debug info I get is:
>> Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&D'.
>> #0 0xb70c4a61 in fileno_unlocked () from /lib/tls/libc.so.6
>> (gdb) bt
>> #1 0xb73ef188 in FCGI_fileno () from /usr/lib/libfcgi.so.0
>> #2 0x0804b039 in cgiMain () at zoo_loader.c:97
>> #3 0x080602b3 in main (argc=2, argv=0xbfd81284) at cgic.c:287
>> armin
>> On Thu, Mar 17, 2011 at 3:42 PM, nicolas bozon <nicolas.bozon at gmail.com>
>> wrote:
>> Hi Armin,
>> You are right, it seems we get a problem, as we could reproduce the segfault
>> this morning before going to the code sprint.
>> We'll try to solve the problem with gerald today and we'lll keep you
>> informed.
>> Best,
>> Nick
>> 2011/3/14 Armin Burger <armin.burger at gmail.com>
>> Hi all
>> after successfully compilation and installation of the zoo_loader.cgi
>> the "GetCapabilities" and "Describe Process" work fine. But as soon as
>> I try to run the Excecute request using the simple HelloPy and a
>> python serviceProvider as hello.py with
>> http://my.website/zoo/?Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name
>> the zoo kernel returns a segmentation fault message like
>> <?xml version="1.0" encoding="UTF-8"?>
>> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xlink="http://www.w 3.org/1999/xlink"
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> xml:lang="en- US" version="1.1.0">
>> </ows:Exception>
>> </ows:ExceptionReport>
>> Same happens when I run it from the command line
>> ./zoo_loader.cgi
>> "Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name"
>> So it seems sort of "caught" segfault from some internal
>> functionality. But I do not know how to do some kind of debugging.
>> Any ideas what I could try?
>> Armin
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110322/416b218e/attachment.html>
More information about the Zoo-discuss
