[ZOO-Discuss] compilation error
Pierre Roudier
pierre.roudier at gmail.com
Tue Mar 22 18:53:08 PDT 2011
Thank you Gerald,
That compiled like a charm on my test server.
Pierre
2011/3/22 Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> Hi Pierre,
> to get the configure script in your ZOO-Kernel directory you should use the
> autoconf command.
> After using the autoconf command from the ZOO-Kernel source directory you
> should then be able to use the configure command.
> Hope it helps,
> Le 22 mars 2011 à 01:43, Pierre Roudier a écrit :
> Hi Gerald,
> Actually I was able to compile cgic206 - that gives me libcgic.a, but
> I'm not too sure what to do with it (I'm not familiar with lib
> linkages) - do you have an example command to execute?
> Also, in the last svn update (r125), bit of a surprise as the
> ./configure does not work in zoo-kernel! - I must have done something
> wrong:
> root at grass:/usr/local/src/zoo/zoo-kernel# ls -a
> . main.cfg README service_internal.h
> service_internal_perl.c service_internal_python.h
> zoo_loader.c
> .. main_conf_read.l service_conf.l
> service_internal_java.c service_internal_perl.h service_loader.c
> zoo_service_loader.c
> configure.ac main_conf_read.y service_conf.y
> service_internal_java.h service_internal_php.c .svn
> Doxyfile Makefile.in service.h
> service_internal_js.c service_internal_php.h ulinet.c
> locale makefile.vc service_internal.c
> service_internal_js.h service_internal_python.c ulinet.h
> root at grass:/usr/local/src/zoo/zoo-kernel# ./configure
> -bash: ./configure: No such file or directory
> Cheers,
> Pierre
> 2011/3/21 Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> Hi Pierre,
> you should compile cgic library from the third/cgic206 directory to be able
> to
> compile the ZOO-Kernel and link it to the libcgic.a static lib.
> I hope you can confirm that solve your issue.
> Best regards,
> Le 21 mars 2011 à 05:57, Pierre Roudier a écrit :
> Hi list,
> I got the following compilation error when compiling the last trunk update:
> g++ -g -O2 -I/usr/include/libxml2 -I../thirds/cgic206 -I.
> -DLINUX_FREE_ISSUE -c zoo_loader.c -fno-common -DPIC -o zoo_loader.o
> g++ -I/usr/local/include -I/usr/include/libxml2
> -I../thirds/cgic206 -I. -DLINUX_FREE_ISSUE zoo_loader.o
> zoo_service_loader.o service_internal.o ulinet.o lex.cr.o
> lex.sr.o service_conf.tab.o main_conf_read.tab.o -o zoo_loader.cgi
> -lcurl -L../thirds/cgic206 -lcgic -lcurl -L/usr/local/lib -lgdal
> -lxml2 -lfcgi -lcrypto
> /usr/bin/ld: cannot find -lcgic
> collect2: ld returned 1 exit status
> make: *** [zoo_loader.cgi] Error 1
> I suspect a static library link is missing but I'm not too sure - if
> anybody here has a pointer that'd be great,
> Pierre
> Scientist
> Landcare Research, New Zealand
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Djay
> ZOO-PSC Chair
> Scientist
> Gérald Fenoy
> GEOLABS
> Siège social :
> Futur Building I
> 1280, avenue des Platanes
> 34970 Lattes
> Tél. fixe : +33 (0) 4 67 43 09 95
> Tél. portable : +33 (0) 6 70 08 25 39
Scientist
More information about the Zoo-discuss
