[ZOO-Discuss] Error when running GRASS processes
Pierre Roudier
pierre.roudier at gmail.com
Tue May 3 20:23:16 PDT 2011
Hi Soeren,
Thanks, it seems to work: I'm bumping into the same error as you now!
root at grass:/usr/local/src/wps-grass-bridge-read-only/Testing/Python#
python SendRequests.py -f ExecuteRequests/v.voronoi.execute.xml -u
"http://localhost/cgi-bin/zoo_loader.cgi"
Start request 0
########### 0 ##########
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
<ows:Exception exceptionCode="InternalError">
<ows:ExceptionText>ZOO Kernel failed to process your request
receiving signal 11 = SIGSEGV</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
If that could be of any help, I had to recompile GDAL to have Xerces support.
Cheers,
Pierre
2011/5/4 Soeren Gebbert <soerengebbert at googlemail.com>:
> Hello Pierre,
> please do not modify the v_voronoi.py/zcfg and v.voronoi.xml files.
> The name of the service provider should be v_voronoi, the same name
> as the base name of the python service file.
> The problem is located in
> Testing/Python/ExecuteRequests/v.voronoi.execute.xml. Please change
> the identifier:
> <ows:Identifier>v.voronoi</ows:Identifier>
> into
> <ows:Identifier>v_voronoi</ows:Identifier>
> This should create a valid execute request. I hope this will work.
> Cheers
> Soeren
> 2011/5/2 Pierre Roudier <pierre.roudier at gmail.com>:
>> Hi Soeren,
>> I've been correcting gms/Testing/Python/XML/v.voronoi.xml but I keep
>> having the following error:
>> <?xml version="1.0" encoding="utf-8"?>
>> <ows:Exception exceptionCode="NoApplicableCode">
>> <ows:ExceptionText>Python module v.voronoi cannot be loaded.
>> </ows:Exception>
>> Here's my /usr/lib/cgi-bin:
>> root at grass:/usr/lib/cgi-bin# ll
>> total 496
>> drwxr-xr-x 3 root root 12288 2011-05-02 12:04 ./
>> drwxr-xr-x 136 root root 69632 2011-04-29 12:17 ../
>> -rw-r--r-- 1 root root 1526 2011-05-02 12:04 GlobalGrassSettings.py
>> drwxr-xr-x 4 root root 4096 2011-04-28 14:25 gms/
>> -rwxr-xr-x 1 root root 979 2011-04-28 13:50 HelloPy.zcfg*
>> -rw-r--r-- 1 root root 675 2011-04-28 14:47 main.cfg
>> -rwxr-xr-x 1 root root 389 2011-03-24 12:06 pywps.cgi*
>> -rwxr-xr-x 1 root root 495 2011-03-24 12:13 pywps_start*
>> -rw-r--r-- 1 root root 142 2011-04-28 13:50 test_service.py
>> -rw-r--r-- 1 root root 3305 2011-04-28 14:52 v_delaunay.zcfg
>> -rw-r--r-- 1 root root 339 2011-04-29 18:03 v_voronoi.py
>> -rw-r--r-- 1 root root 2979 2011-05-02 11:24 v_voronoi.zcfg
>> -rw-r--r-- 1 root root 12706 2011-04-28 14:25 ZOOGrassModuleStarter.py
>> -rwxr-xr-x 1 root root 355333 2011-04-28 14:45 zoo_loader.cgi*
>> Here's the content of v_voronoi.* and v.voronoi.xml:
>> root at grass:/usr/lib/cgi-bin# more v_voronoi.zcfg | grep voronoi
>> [v_voronoi]
>> Abstract = http://grass.osgeo.org/grass70/manuals/html70_user/v.voronoi.html
>> serviceProvider = v.voronoi
>> root at grass:/usr/lib/cgi-bin# more v_voronoi.py | grep voronoi
>> def v_voronoi(m, inputs, outputs):
>> service.fromMaps("v.voronoi", inputs, outputs)
>> root at grass:/usr/lib/cgi-bin# more gms/Testing/Python/XML/v.voronoi.xml
>> | grep voronoi
>> <ows:Abstract>http://grass.osgeo.org/grass70/manuals/html70_user/v.voronoi.html</ows:Abstract>
>> Obviously the problem is that ZOO cannot find the v.voronoi module.
>> But I can't really understand if this is a problem of GRASS config in
>> GlobalGrassSettings.py, or a problem in the v_voronoi.* files.
>> Cheers,
>> Pierre
>> 2011/4/29 Soeren Gebbert <soerengebbert at googlemail.com>:
>>> Hello,
>>> ... <ows:Exception exceptionCode="InvalidParameterValue">
>>>>> <ows:ExceptionText>The value for <indetifier> seems to be
>>>>> wrong (v.voronoi). Please, ensure that the process exist using the
>>>>> GetCapabilities request.</ows:ExceptionText>
>>>>> </ows:Exception>
>>>> This is an unexpected error ... i don't know why this is not working
>>>> with ZOO WPS??? I am using a POST request to deliver the XML content,
>>>> maybe Gerald can clarify this issue?
>>> Sorry, i have to correct me:
>>> Everything is fine with ZOO but the service name in the XML execute
>>> request and in the zcfg files are different. You need to change the
>>> name v.voronoi into v_voronoi in the XML request file.
>>> Best regards
>>> Soeren
>>>> Best regards
>>>> Soeren
>>>>> Cheers,
>>>>> Pierre
>>>>>> Best regards
>>>>>> Soeren
>>>>>>> Your help, and the efforts you are putting on open-source software,
>>>>>>> is greatly appreciated.
>>>>>>> Best,
>>>>>>> Pierre
>>>>>>>> Best regards
>>>>>>>> Soeren
>>>>>>>> 2011/4/28 Pierre Roudier <pierre.roudier at gmail.com>:
>>>>>>>>> Dear zoo-keepers,
>>>>>>>>> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
>>>>>>>>> I've added two GRASS processes to my /usr/lib/cgi-bin:
>>>>>>>>> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
>>>>>>>>> HelloPy.zcfg
>>>>>>>>> v_delaunay.zcfg
>>>>>>>>> v_voronoi.zcfg
>>>>>>>>> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
>>>>>>>>> to try to make a Voronoi tesselation or a Delaunay triangulation of a
>>>>>>>>> dummy points shapefile. In both cases, I got the following error when
>>>>>>>>> running the process:
>>>>>>>>> <ows:ExceptionText>Python module v_delaunay cannot be loaded.
>>>>>>>>> </ows:Exception>
>>>>>>>>> Any suggestion?
>>>>>>>>> Cheers,
>>>>>>>>> Pierre
>>>>>>>>> Scientist
>>>>>>>>> Landcare Research, New Zealand
>>>>>>>>> _______________________________________________
>>>>>>>>> Zoo-discuss mailing list
>>>>>>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>>>>>>> Scientist
>>>>> Scientist
>> Scientist
Scientist
More information about the Zoo-discuss
