[ZOO-Discuss] problems getting zoo_loader.cgi running
Gérald Fenoy
gerald.fenoy at geolabs.fr
Wed May 4 14:47:20 PDT 2011
Hi Matthias,
It sounds really strange that the ZOO-Kernel is giving you this kind of result. Indeed, this should never occurs except if something went wrong during the compilation process and more precisely linking your Kernel to a different cgic library than the one which is provided in the SVN source tree.
Please, can you confirm that the first step in your compilation process was to compile the cgic from the thirds/cgic206 directory ? If not, then can you try to recompile your ZOO-Kernel linking it against this libcgcic ? Indeed, if the libcgic is well compiled in the thirds/cgic206, then your Kernel will be linked against the proper libcgic else if you get libcgic installed from a package or manually then the compilation process will use this one in place of the thirds/cgic206 which was not found.
Hope to hear from you to be able to find a solution to this issue.
Best,
Gérald Fenoy
Le 4 mai 2011 à 17:40, Matthias Lendholt <matthias.lendholt at gfz-potsdam.de> a écrit :
> Hi all,
> I'm new to the zoo and coming from the java world I'm already lost with
> getting the zoo_loader.cgi running :-)
> I followed the instructions from the wiki page. Some libs were missing
> before make was successful. Then apache2 missed JAVA_HOME but this was
> also no problem. However, calling
> http://192.168.56.101/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0
> ends up in an Internal Server Error.
> /var/log/apache2/error.log just mourns "Premature end of script headers:
> zoo_loader.cgi"
> Not very meaningful...
> Because cgi-bin/mapsserv (MapServer) is working, it shouldn't be an
> apache2 problem.
> Any ideas / general advices?
> Thanks in advance!
> Best,
> Matthias
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss
