[Zoo-discuss] Caching, incorrect caching file(?)
Farkas H
farkas.dus at gmail.com
Thu Nov 1 03:25:05 PDT 2012
Hi Gérald,
you were right. With revision 375 the problem is solved.
Sorry I didn't notice that.
Regards,
Farkas
On 31 October 2012 23:52, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Hi Farkas,
> can you please confirm that you built your ZOO-Kernel using the revision 375 [1] or upper ?
> This should solve the issue when reading the file.
> Hope this helps,
> Best regards,
> [1] http://zoo-project.org/trac/browser/trunk/zoo-project/zoo-kernel/service_internal.c?rev=375
> Gérald Fenoy
> Le 31 oct. 2012 à 12:58, Farkas H <farkas.dus at gmail.com> a écrit :
>> Hi list,
>> I'm checking the caching mechanism for referenced wfs-data.
>> The caching works very well.
>> But I've got some strange behavior accessing referenced wfs-data from
>> localhost. I've setup a GeoServer wfs (version 2.2) with polygons
>> based on Oracle XE (version 10).
>> If I compute for example the centroids via CentroidPy the referenced
>> wfs data is stored in the cache directory and I get a correct
>> response.
>> Next time I execute the same request I get
>> (1) an error message: XML parsing of GML file failed : not well-formed ...
>> (2) the response file has no features:
>> <ogr:FeatureCollection xsi:schemaLocation="http://ogr.maptools.org/
>> store4836.xsd"></ogr:FeatureCollection>
>> There seems to be nothing wrong with the caching file.
>> As I can see zooWPS caching files usually have just one line. This
>> caching file has two lines:
>> line 1: <?xml version="1.0" encoding="UTF-8"?>
>> line 2: <wfs:FeatureCollection xml ... </wfs:FeatureCollection>
>> After I corrected the caching file manually everything went well.
>> What went wrong?
>> I'm wondering if I made any mistakes setting up the wfs.
>> I would appreciate any advice.
>> Regards,
>> Farkas
>> Zoo-discuss mailing list
>> Zoo-discuss at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss
