[Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
Fenoy Gerald gerald.fenoy at geolabs.fr
Mon Dec 2 08:23:25 PST 2013
Christian,
even if it should work using the parameters I sent (at least with newer ZOO-Kernel version), I guess there is still something wrong in the ZOO-Kernel you are using. But there is probably some way to solve, I guess you may first try to define the application/json mimeType as the default one in the Union.zcfg file for the output Result.
Hope to hear back from you and this sole your issue,
Best regards
Gérald Fenoy
Le 2 déc. 2013 à 17:00, Christian Rüh <christian.rueh at uni-rostock.de> a écrit :
> Hi Gerald,
> thank you very much :-)
> Unfortunately that does not change anything and the result is still the same. RawDataOutput and the mimeType seem to not to play any role at all when it comes to the response. It remains in GML format. I'm pretty lost now and don't know what else could be wrong...
> Cheers and thanks,
> Christian
> ________________________________________
> Von: Fenoy Gerald [gerald.fenoy at geolabs.fr]
> Gesendet: Montag, 2. Dezember 2013 16:39
> An: Christian Rüh
> Cc: ZOO-discuss
> Betreff: Re: [Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
> Hi Christian,
> I think that the new file attached to this email should fix the issue by adding a mimeType attribute to a new Output node added to the request sent by your zoo-ogr2.html file.
> I noticed that you got both ResponseDocument and RawDataOutput nodes in your POST request which sounds odd to me.
> I hope to hear back from you and the file solve your issue.
> Best regards,
> Gérald Fenoy
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131202/bb6ebd14/attachment.pgp>
More information about the Zoo-discuss mailing list
