[Zoo-discuss] ZOO and Mapserver 6.4
Fenoy Gerald
gerald.fenoy at geolabs.fr
Thu Dec 19 02:08:37 PST 2013
Hi Luca,
nice to hear that you are trying to use the MapServer support with the 6.4.0 version. I never tried it before as I’m mainly using 6.2.0 version by now.
Nevertheless, I successfully link the ZOO-Kernel against a fresh MapServer 6.4.0 build on MacOS X by using the patch attached to this email.
I hope it helps and will work for you.
Note that I didn’t tried to use the support once compiled as I get the mapserver-6.2.0 library setup already. But I would appreciate to hear from your tests using this MapServer version.
Hop ego hear back from you,
Best regards,
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131219/dac2bf96/attachment.obj>
Le 19 déc. 2013 à 09:45, Luca Delucchi <lucadeluge at gmail.com> a écrit :
> Hi everybody,
> MapServer 6.4 has not more mapserver-config so it is impossible to
> compile ZOO against this version of MapServer, Gerald do you have any
> info about it?
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131219/dac2bf96/attachment.pgp>
More information about the Zoo-discuss
