[Zoo-discuss] BufferPy problem
Gérald Fenoy gerald.fenoy at geolabs.fr
Sun Jan 13 11:50:41 PST 2013
Hi Farkas,
I forgot to say in my previous email that using rev. 389 should solve issue using UnionPy service.
I'm not sure to follow what happen when you use POST request. Did you try using curl tool from command line with -v option to get a verbose output ? If yes, what was the output ? I guess it would be helpful for testing your ZOO-Kernel version and make sure it can handle properly the POST requests to run curl from command line.
Did you take a look at the Apache error log ? Maybe there is some user privileges issue due to running zoo_loader.cgi from the command line using another user (which make some files owned by this user).
It would be helpful to get more details on what is not working what is exactly the XML request you are using to request the ZOO-Kernel.
I hope you can provide more details.
Waiting for your answer,
Best regards,
Gérald Fenoy
Le 13 janv. 2013 à 20:43, Farkas H <farkas.dus at gmail.com> a écrit :
> Firebug reports that parsing the xml causes an error [2] when
> processing the JavaScript via http-Post request.
> Do you have any idea?
More information about the Zoo-discuss mailing list
