[Zoo-discuss] fastcgi + python + numpy?
Fenoy Gerald gerald.fenoy at geolabs.fr
Tue Jul 9 02:03:17 PDT 2013
Hi Tim,
unfortunately I have to concede that there was no more work made on the fastcgi side of the ZOO-Kernel so we usually avoid using fastcgi version and prefer the cgi one.
Note that the fastcgi support should work correctly for both GetCapabilities and DescribeProcess but some trouble should occur when trying to run Execute request.
Note that the Execute request should not work properly mainly because of the way fastcgi is redirecting standard input, output and error. We have to use specific headers to get the redirection working and in some places we are still using the standard headers which do not use the redirection implying issue when using those code section.
We are really interested in getting the full fastcgi support working for ZOO-Project but it would imply some modifications in the source code to get it working properly.
Nevertheless, if it is important to you to get the fastcgi support working for all requests, then I would like to invite you to submit a ticket on the Trac system to get it treated.
Anyway, what is interesting in your testings is that you said that your request works the first time. When you said "without the import statement" of numpy the service will run fine, I guess you are still speaking about the cgi version or are you speaking about the fastcgi one ? If it is the fastcgi one then I would like to ask you to share your service to let me have a look at it. It may be caused by unneeded redirection of standard output/input and error in bumpy which should be avoided.
Waiting for your answer,
Best regards,
Gérald Fenoy
Le 9 juil. 2013 à 04:57, Tim Erwin <taerwin at gmail.com> a écrit :
> Hi all,
> I am having difficulty setting up a python service that utilises numpy. It works fine under cgi but not under fastcgi. Under fastcgi it only works every second request i.e initial load works second request crashes and service is restarted, next request works etc.
> It seems to be the import of numpy, that is causing the problems as without the import statement the python service will run fine. Has anyone run into this before and have any ideas?
> Cheers,
> Tim
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
