[Zoo-discuss] suggestions
nicolas bozon nicolas.bozon at gmail.com
Mon Mar 18 01:27:52 PDT 2013
Hello Stefano
Yes, ZOO-Project can be very usefull to run GDAL algorithms or other C
library as WPS services.
Some basics GDAL exemples are available on the svn trunk:
http://zoo-project.org/trac/browser/trunk/zoo-project/zoo-services/gdal
You should be able to compile and install on any Linux distrib. I remember
some CentOS install guide was written long ago:
http://zoo-project.org/docs/kernel/install-centos.html
And yes, you can use WMS or WFS from/to Geoserver or MapServer with your
ZOO install.
Do not hesitate to post on this list again to get help or to share your
experience using ZOO.
Hope it helps
Best,
Nick
Le lundi 18 mars 2013, S.Campagnolo - GAIAG company <
stefano.campagnolo at gaiagsat.eu> a écrit :
> Dear zoo project,
> you ZOO it's very interesting. I have some questions to understand if we
> are on the right track or if we have misunderstood some points.
> I would like to know if is it useful for our approach: we work with C/C++
> using GDAL approach.
> It works well also with last centos versions 6.2?
> Is it compatible with use of geoserver or ZOO represents an alternative?
> Thank you very much for your first help.
> Regards
> Stefano
> Stefano Campagnolo
> GaiaG company - satellite data for environmental monitoring
> e-mail: stefano.campagnolo at gaiagsat.eu
> Registered office: Via C.Cattaneo 20, 26044 Grontardo (CR), Italy
> Operative site: Via Aurelio Saffi 34/A, 47521 Cesena, Italy
> ph.: +39 0547 1902834
> mobile: +39 3479197627
> fax: +39 0373 5662002
> Skype: Cimabue250
> web: www.gaiagSat.eu
> _______________________________________________________________
> This e-mail and any attachments is a confidential correspondence intended
only for use of the individual or entity named above. If you are not the
intended recipient or the agent responsible for delivering the message to
the intended recipient, you are hereby notified that any disclosure,
distribution or copying of this communication is strictly prohibited. If
you have received this communication in error, please notify the sender by
phone or by replying this message, and then delete this message from your
system.
> Prima di stampare questa comunicazione consideratene, per favore,
l'impatto ambientale.
> Please consider the environment before printing this email.
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20130318/fed24fbb/attachment.html>
More information about the Zoo-discuss mailing list
