[Zoo-discuss] Debugging WFS request in GDB
Jerome Villeneuve Larouche
jlarouche at mapgears.com
Thu Aug 21 06:53:18 PDT 2014
I've got another little problem. I'm trying to debug into service.c from
zoo-service/ogr/base-vect-ops. Is it even possible since it's loaded
dynamically?
On 14-08-21 08:02 AM, Jerome Villeneuve Larouche wrote:
> Hello,
> Thanks a lot. I should have thought about the URL Encode :).
> I'm also grateful for the POST request tip, this will be really useful.
> On 14-08-21 03:49 AM, Fenoy Gerald wrote:
>> Hello Jerome,
>> running zoo_loader.cgi from GDB for debugging purpose should work.
>> Nevertheless, when I red your request I could notice that the
>> xlink:href was not encoded using URLEncode, so the request was not
>> correctly parsed by the ZOO-Kernel.
>> I take advantage of this email about gdb usage to mention that you
>> can also test the POST requests using GDB also (this way you won’t
>> have to take care of such encoding of embedded URLs). So, to use GDB
>> for debugging POST requests, you can use:
>> 1) export REQUEST_METHOD=POST
>> 2) export CONTENT_TYPE=text/xml
>> 3) gdb ./zoo_loader.cgi
>> 4) run < my_request.xml
>> I hope that this will solve your issue,
>> Best regards,
>> Le 20 août 2014 à 21:50, Jerome Villeneuve Larouche
>> <jlarouche at mapgears.com> a écrit :
>>> Hello,
>>> I'm trying to run zoo_loader.cgi in GDB to debug C services. The
>>> thing is that in my requests I use WFS url for the DataInputs and it
>>> seems that the "request" in the WFS is the one Zoo is trying to
>>> read, so I get "Unenderstood request value. Please check that it was
>>> set to GetCapabilities, DescribeProcess or Execute."
>>> I'm trying to run this request in GDB.
>>> "request=Execute&service=WPS&version=1.0.0&Identifier=Buffer&DataInputs=BufferDistance=10 at datatype=interger;InputPolygon=Reference at xlink:href=myserver.com/ows?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=feature:drainage&SRS=EPSG:3857&FeatureID=drainage.1811&RawDataOutput=Result at mimeType=application/json"
>>> Am I missing something to run that request in GDB?
>>> It works fine when I send it through Apache.
>>> Thank you
>>> Jérôme Villeneuve Larouche
>>> www.mapgears.com
>>> Zoo-discuss mailing list
>>> Zoo-discuss at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
www.mapgears.com
More information about the Zoo-discuss
