[Zoo-discuss] WPS Execute request - POST reference
Alexandre Dubé
adube at mapgears.com
Wed Aug 27 06:22:52 PDT 2014
Hi list,
In summary
Does Zoo support wps:Reference node using method="POST" ?
Details
It will be easier to explain using examples. See the attached
files. Using curl, you can easily execute the requests and see the
first one working (method=GET) and the other doesn't (method=POST). The
latter seems to be correctly set (the XML seems okay). So I'm not sure
where the problem
is. Does Zoo support wps:Reference node using method="POST" or is there
something wrong with my XML definition ?
GET:
curl -X POST -d @execute-wfs5-get-custom.xml http://zoo-project.org/cgi-bin-new1/zoo_loader.cgi --header "Content-Type:text/xml"
POST:
curl -X POST -d @execute-wfs4-post-custom.xml http://zoo-project.org/cgi-bin-new1/zoo_loader.cgi --header "Content-Type:text/xml"
Any hint ?
Alexandre Dubé
T: +1 418-696-5056 #203
http://www.mapgears.com/
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140827/c05afb11/attachment.html>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140827/c05afb11/attachment.xml>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140827/c05afb11/attachment-0001.xml>
More information about the Zoo-discuss
