[Zoo-discuss] don't find the directory zoows in OSGeolive
lamiaa khazaz lamiaa.perso at gmail.com
Sat Jul 19 18:59:51 PDT 2014
:) thanks to you for your help.
Best Regard
2014-07-20 1:55 GMT+00:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hey,
> thank you ! to thanks me twice …
> Best
> Le 20 juil. 2014 à 03:15, lamiaa khazaz <lamiaa.perso at gmail.com> a écrit :
> > Hello gerald
> > thank you for your quick response.
> > i will use the workshop 2013
> > 2014-07-19 19:36 GMT+00:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > Dear lamiaa,
> > thanks a lot for giving a try to this workshop.
> > I would like first to inform you that I would recommend that you may try
> using the 2013 workshop which is more simple for a first approach than the
> old 2010 one. In the 2010 workshop we were willing to present both C and
> Python version of services but maybe trying using C code as a first try may
> make the learning more difficult I think.
> > Furthermore you may face issue (not when running the workshop material
> but using the 2010 ZOO-Kernel version) specifics to this version which is
> not much used nowadays.
> > So I would recommend that you use this workshop [1].
> > Once you have the 2013 ZOO-Project Workshop running on your virtual
> machine, then if you want to learn how to code C services you can then go
> back to the 2010 Workshop material. I think it’s better this way.
> > Hope this helps and convince you,
> > Best regards,
> > [1] http://zoo-project.org/docs/workshop/2013/index.html
> > Le 19 juil. 2014 à 20:01, lamiaa khazaz <lamiaa.perso at gmail.com> a
> écrit :
> > > Hello
> > > i'm trying to do the workshop 2010 for Zoo project, using the
> OSGeoLive virtual machine.
> > > The test of zoo project is working perfectly but i don't find the
> directory:
> > >  /home/user/zoows
> > > i tried cd ~/zoows  the answer is "no such file or directory"
> > > thank you
> > > _______________________________________________
> > > Zoo-discuss mailing list
> > > Zoo-discuss at lists.osgeo.org
> > > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140720/e9ea3b18/attachment.html>
More information about the Zoo-discuss mailing list
