[Zoo-discuss] prerequisites to install zooProject
Fenoy Gerald gerald.fenoy at geolabs.fr
Mon Jul 28 01:42:44 PDT 2014
Bonjour :)
You do not only need to have the directory uncompressed on your window environment, you will also need to build them to create binaries version of the library which you can use to link you ZOO-Kernel against.
Hope this helps,
Best regards,
Le 28 juil. 2014 à 05:20, lamiaa khazaz <lamiaa.perso at gmail.com> a écrit :
> bonsoir
> i would like to install ZooProject following this url: http://www.zoo-project.org/docs/kernel/install-prerequisites.html
> i downloaded the files
> 	• autoconf ( http://www.gnu.org/software/autoconf/ )
> 	• cgic ( http://www.boutell.com/cgic )
> 	• cURL ( http://curl.haxx.se )
> 	• FastCGI ( http://www.fastcgi.com )
> 	• Flex & Bison ( http://flex.sourceforge.net/ http://www.gnu.org/software/bison/ )
> 	• libxml2 ( http://xmlsoft.org )
> 	• OpenSSL ( http://www.openssl.org )
> 	• Python ( http://www.python.org )
> and put them in a directory. that's it ? or should do something with them to install them ?
> thank you
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140728/259b95d1/attachment.pgp>
More information about the Zoo-discuss mailing list
