[Zoo-discuss] during compilation - fatal error: cgic.h: No such file or directory
karsten karsten at terragis.net
Tue Feb 3 09:55:08 PST 2015
 Hi Gerald et all,
It seems I went through the updated installation procedure but my MapMint
web page but it still has a hick-up when I try to access it. For
http://terra3.terragis.net/ui/public/ it says e.g. "The requested URL
/ui/public/ was not found on this server" when I try to navigate to the /ui
or the /ui/Dashboard directory. /ui is forwarded to
http://terra3.terragis.net/ui/public/ but it seems that some setting for
apache or the symbolic links are not yet correct.
I got all these 3 symb links set:
sudo ln -s $SRC/mapmint/mapmint-ui/ /var/www/html/ui
sudo ln -s $SRC/mapmint/public_map/ /var/www/html/pm
sudo ln -s $SRC/mapmint/mapmint-services/ /usr/lib/cgi-bin/mm
And also the apache.conf web bloc as noted in the install notees
Also did : Edit the file /etc/apache2/conf-available/serve-cgi-bin.conf,
then replace +SymLinksIfOwnerMatch by +FollowSymLinks.
Is there any symb link missing or what will I need to look for to make it
work ?
Below are some additional notes on the installation notes:
In the installation instructions
https://github.com/mapmint/mapmint/blob/master/INSTALL.md it seem to me that
step (2)  needs to de done before (1) , sequence might need to be updated to
avoid user confusion
(2)
(1)
sudo cp cgi-env/* /usr/lib/cgi-bin/mm/
There seems to be a typo for the ghostscript
sudo apt-get install .... ghistscript
Should be "ghostscript"
Cheers
Karsten
-----Original Message-----
From: Fenoy Gerald [mailto:gerald.fenoy at geolabs.fr]
Sent: Wednesday, January 21, 2015 6:05
To: karsten at terragis.net
Cc: ZOO-discuss
Subject: Re: during compilation - fatal error: cgic.h: No such file or
directory
Hello Karsten,
sorry for late reply.
My responses inline bellow.
> Le 16 janv. 2015 à 18:33, karsten <karsten at terragis.net> a écrit :
> Oh yes I must have missed the cd command to go there , now it worked.
> I still cant seem o start the system but while troubleshooting seem to
> be down to the "Final tweaks" section to get this wrapped up , there a
> couple of things did not work out form the description on my system
> To create symbolic links the first two work:
> sudo ln -s /home/src/mapmint/mapmint-ui/ /var/www/html/ui sudo ln -s
> /home/src/mapmint/public_map/ /var/www/html/pm
> The third one does not
> sudo ln -s /home/src/mapmint/mapmint-services/ /usr/lib/cgi-bin/mm
> Gives me
> ln: failed to create symbolic link '/usr/lib/cgi-bin/mm/mapmint-services':
> File exists
> And sure enough the dir /usr/lib/cgi-bin/mm physically exists as we
> did some lines above a copy to cerate it
> ( Install QREncode service    .....    sudo cp cgi-env/*
> /usr/lib/cgi-bin/mm/ )
> Is that ok to get the system up and running ? What should I do about
> it - just ignore ?
When you run the copy to deploy the QREncode service, you should have the mm
directory available already.
What is important here is that /usr/lib/cgi-bin/mm should point (be a link
to) $SRC/mapmint/mapmint-services.
In other case it will fail.
> The other things I noticed is that in the "Create required
> directories" section two commands fail
> 1. works:  sudo chown -R www-data:www-data /var/data
> 2. fails: sudo chown www-data:www-data /usr/lib/cgi-bin/main.cfg
> chown: cannot access '/usr/lib/cgi-bin/main.cfg': No such file or
> directory
You are right, the correct location should be /usr/lib/cgi-bin/mm/main.cfg.
> 3. also works:  sudo chown www-data:www-data
> /usr/lib/cgi-bin/mapcache.xml
> 4. fails: sudo chown -R www-data:www-data /var/www/html/pm/styles
> chown: cannot access '/var/www/html/pm/styles': No such file or
> directory
This was created few lines before with the command:
sudo mkdir -p /var/www/html/pm/styles
So there is no reason that the chown command failed.
> What do I need to do to fix this - items 2 and 3 above  ?
> (as I can't  access my MapMint installation so far)
> Also wondering when I looked at $SRC/mapmint/mapmint-services/main.cfg
> What settings I need to change. For example do I need to install
> libreoffice , as it lists :
> [oo]
> path=/opt/libreoffice-4.1/program/python
> ghostscript=/usr/local/bin/gs
For the main.cfg file, you can now read [1] for more informations about what
values you should change to make it working.
Indeed you need to install libreoffice, xvfb and ghostscript to have access
to the print capabilities. This was added the INSTALL.md file too [2].
> Thanks
> Karsten
Thanks to you for trying it out !
Best regards,
[1] https://github.com/mapmint/mapmint/blob/master/Main_cfg.md
[2] https://github.com/mapmint/mapmint/blob/master/INSTALL.md
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
