[Zoo-discuss] Getting error when working with IIS
Pankaj Pedram
pankaj.pedram at rolta.com
Fri Jun 26 03:00:09 PDT 2015
Hello Fenoy,
I tried to compile the zoo kernel, but got following error for both Visual
Studio command prompt 2008 and Visual Studio command prompt 2010:
D:\ZooProject\Zoo680\zoo-project\zoo-kernel>nmake /f makefile.vc
Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
link zoo_loader.obj request_parser.obj response_print.obj
server_internal.obj caching.obj ulinet.obj main_conf_r
ead.tab.obj lex.cr.obj service_conf.tab.obj lex.sr.obj
zoo_service_loader.obj ./libzoo_service.lib /out:zoo_loader.cgi D:\Zo
oProject\fcgi-2.4.1-SNAP-0311112127/libfcgi/Release/libfcgi.lib
D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/libeay32.l
ib D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/ssleay32.lib
D:\ZooProject\Zoo680\zoo-project\zoo-kernel\intl/libintl.li
b D:\ZooProject\Zoo680\zoo-project\zoo-kernel\libxml/libxml2.lib
D:\ZooProject\Zoo680\zoo-project\zoo-kernel\gdal\lib/gdal_i.
lib D:\ZooProject\Zoo680\zoo-project\zoo-kernel\curl/lib/libcurl.lib
/machine:i386 ./../../thirds/cgic206/libcgic.lib
Microsoft (R) Incremental Linker Version 9.00.30729.01
Creating library zoo_loader.lib and object zoo_loader.exp
server_internal.obj : error LNK2019: unresolved external symbol
_BIO_free_all referenced in function _base64
server_internal.obj : error LNK2019: unresolved external symbol _BIO_ctrl
server_internal.obj : error LNK2019: unresolved external symbol _BIO_write
server_internal.obj : error LNK2019: unresolved external symbol _BIO_push
server_internal.obj : error LNK2019: unresolved external symbol _BIO_s_mem
_BIO_set_flags referenced in function _base64
server_internal.obj : error LNK2019: unresolved external symbol _BIO_new
_BIO_f_base64 referenced in function _base64
server_internal.obj : error LNK2019: unresolved external symbol _BIO_read
referenced in function _base64d
_BIO_new_mem_buf referenced in function _base64d
caching.obj : error LNK2019: unresolved external symbol _EVP_MD_CTX_cleanup
referenced in function "char * __cdecl getMd5(cha
r *)" (?getMd5@@YAPADPAD at Z)
caching.obj : error LNK2019: unresolved external symbol _EVP_DigestFinal_ex
caching.obj : error LNK2019: unresolved external symbol _EVP_DigestUpdate
referenced in function "char * __cdecl getMd5(char
caching.obj : error LNK2019: unresolved external symbol _EVP_DigestInit
referenced in function "char * __cdecl getMd5(char *)
caching.obj : error LNK2019: unresolved external symbol _EVP_md5 referenced
in function "char * __cdecl getMd5(char *)" (?get
Md5@@YAPADPAD at Z)
zoo_loader.cgi : fatal error LNK1120: 15 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio
9.0\VC\BIN\link.EXE"' : return code '0x460'
Stop.
Kindly help me to solve the issue as soon as possible.
Thanking you in anticipation.
Regards,
Pankaj Pedram
-----Original Message-----
Sent: Thursday, June 25, 2015 6:05 PM
To: Pankaj Pedram
Cc: ZOO-discuss
Subject: Re: [Zoo-discuss] Getting error when working with IIS
Hello Pankaj,
thanks a lot for your feedbacks and congratulations for building the
ZOO-Kernel on your windows system.
I would like to make sure you are using the right version of the code to
build. First of all, can you confirm that you have generated both the
zoo_loader.cgi and the libzoo_service.dll files ? I start by asking this
question, cause when I run the zoo_loader.cgi command locally, I get two
Exception nodes, so one more than the ExceptionReport you reported. The
first one is the exact same as your's but the second reference the service
locator. In case you are not using the latest trunk version, I would like to
invite you to try with the revision 680 [1]. If you have both zoo_loader.cgi
and the libzoo_service.dll generated, please make sure to copy both of them
to your cgi-bin directory.
After making sure you are using the latest ZOO-Kernel version, you should
take a look at your main.cfg file. Indeed, a specific logPath parameter is
required in the [main] section of the main.cfg file to run on IIS server
properly. This parameter should take the full path of a log file used to
output any debug messages. Other parameters of the main.cfg should be also
correctly defined but for a simple GetCapabilities request, defining the
logPath should be enough. You should obviously make sure that the IIS user
is allowed to write the log file.
I hope this answer will help to solve your issue,
Best regards,
[1] http://zoo-project.org/trac/changeset/680
> Le 25 juin 2015 à 07:55, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit :
> Hi,
> Greetings!!!
> I have been trying to Install zoo kernel on IIS.
> I was able to compile the zoo kernel and was able generate the
> zoo_loader.cgi file.
> I placed the zoo_loader.cgi and main.cfg file(modified the
> ServerAddress ) in C:\inetpub\wwwroot\cgi-bin
> Then through the command prompt I was able to generate same response as we
> get by installing Apache Server.
> I got the response as below :
> c:\inetpub\wwwroot\cgi-bin>zoo_loader.cgi
> Content-Type: text/xml; charset=utf-8
> Status: 400 Bad request
> <?xml version="1.0" encoding="utf-8"?>
> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3
> .org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" v
> ersion="1.1.0">
> <Exception exceptionCode="MissingParameterValue" locator="request">
> <ExceptionText>Parameter <request> was not
> specified</ExceptionText>
> </Exception>
> </ExceptionReport>
> But when I try to access through browser
> (http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0)
> I get error as :
> HTTP Error 502.2 - Bad Gateway
> The specified CGI application misbehaved by not returning a complete set
> of HTTP headers. The headers it did return are "".
> It will be helpful for me if you could help me out with tis issue.
> Regards,
> Pankaj Pedram
> 07506934293
> pankaj.p.pedram at gmail.com
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss
