[Zoo-discuss] Getting error when working with IIS
Pankaj Pedram
pankaj.pedram at rolta.com
Mon Jun 29 05:51:18 PDT 2015
Hello Fenoy,
Thanks for your response.
I have configured the paths in nmake.opt file itself, still I am getting
same error.
Please find the attached file(nmake.opt)
Hope I will be able configure zoo project soon in IIS .
Regards,
Pankaj
-----Original Message-----
Sent: Friday, June 26, 2015 4:22 PM
To: Pankaj Pedram
Cc: ZOO-discuss
Subject: Re: [Zoo-discuss] Getting error when working with IIS
Hello,
when building ZOO-Kernel on windows platforms you should define some options
on the command line.
Some are optional but some are not, like libxml2, openssl, goal and so on.
That is why you end with the following reference:
D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/ssleay32.lib
Which means that you did not define the SSL_DIR.
You will require to define also GDAL_DIR, INTL_DIR and XML2_DIR as a
minimum.
You may check the name.opt file in the zoo-kernel directory to see available
and required options.
For optional support, such as Python, you can simply define PY_DIR to
activate it.
To define those options you can use the « set » command or define the values
directly from the command line, something like:
nmake /f makefile.vc GDAL_DIR=\MMBK\SRCS\gdal-version
SSL_DIR=\MMBK\SRCS\openssl
I hope it will help you to solve your compilation issue.
Best regards,
> Le 26 juin 2015 à 12:00, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit :
> Hello Fenoy,
> I tried to compile the zoo kernel, but got following error for both
> Visual Studio command prompt 2008 and Visual Studio command prompt 2010:
> D:\ZooProject\Zoo680\zoo-project\zoo-kernel>nmake /f makefile.vc
> Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
> Copyright (C) Microsoft Corporation. All rights reserved.
> link zoo_loader.obj request_parser.obj response_print.obj
> server_internal.obj caching.obj ulinet.obj main_conf_r
> ead.tab.obj lex.cr.obj service_conf.tab.obj lex.sr.obj
> zoo_service_loader.obj ./libzoo_service.lib /out:zoo_loader.cgi D:\Zo
> oProject\fcgi-2.4.1-SNAP-0311112127/libfcgi/Release/libfcgi.lib
> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/libeay32.l
> ib D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/ssleay32.lib
> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\intl/libintl.li
> b D:\ZooProject\Zoo680\zoo-project\zoo-kernel\libxml/libxml2.lib
> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\gdal\lib/gdal_i.
> lib D:\ZooProject\Zoo680\zoo-project\zoo-kernel\curl/lib/libcurl.lib
> /machine:i386 ./../../thirds/cgic206/libcgic.lib
> Microsoft (R) Incremental Linker Version 9.00.30729.01
> Creating library zoo_loader.lib and object zoo_loader.exp
> server_internal.obj : error LNK2019: unresolved external symbol
> _BIO_free_all referenced in function _base64
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_ctrl
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_write
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_push
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_s_mem
> _BIO_set_flags referenced in function _base64
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_new
> _BIO_f_base64 referenced in function _base64
> server_internal.obj : error LNK2019: unresolved external symbol _BIO_read
> referenced in function _base64d
> _BIO_new_mem_buf referenced in function _base64d
> caching.obj : error LNK2019: unresolved external symbol
> _EVP_MD_CTX_cleanup referenced in function "char * __cdecl getMd5(cha
> r *)" (?getMd5@@YAPADPAD at Z)
> _EVP_DigestFinal_ex referenced in function "char * __cdecl getMd5(cha
> caching.obj : error LNK2019: unresolved external symbol _EVP_DigestUpdate
> referenced in function "char * __cdecl getMd5(char
> caching.obj : error LNK2019: unresolved external symbol _EVP_DigestInit
> referenced in function "char * __cdecl getMd5(char *)
> caching.obj : error LNK2019: unresolved external symbol _EVP_md5
> referenced in function "char * __cdecl getMd5(char *)" (?get
> Md5@@YAPADPAD at Z)
> zoo_loader.cgi : fatal error LNK1120: 15 unresolved externals
> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio 9.0\VC\BIN\link.EXE"' : return code '0x460'
> Stop.
> Kindly help me to solve the issue as soon as possible.
> Thanking you in anticipation.
> Regards,
> Pankaj Pedram
> -----Original Message----- From: Fenoy Gerald
> Sent: Thursday, June 25, 2015 6:05 PM
> To: Pankaj Pedram
> Cc: ZOO-discuss
> Hello Pankaj,
> thanks a lot for your feedbacks and congratulations for building the
> ZOO-Kernel on your windows system.
> I would like to make sure you are using the right version of the code to
> build. First of all, can you confirm that you have generated both the
> zoo_loader.cgi and the libzoo_service.dll files ? I start by asking this
> question, cause when I run the zoo_loader.cgi command locally, I get two
> Exception nodes, so one more than the ExceptionReport you reported. The
> first one is the exact same as your's but the second reference the service
> locator. In case you are not using the latest trunk version, I would like
> to invite you to try with the revision 680 [1]. If you have both
> zoo_loader.cgi and the libzoo_service.dll generated, please make sure to
> copy both of them to your cgi-bin directory.
> After making sure you are using the latest ZOO-Kernel version, you should
> take a look at your main.cfg file. Indeed, a specific logPath parameter is
> required in the [main] section of the main.cfg file to run on IIS server
> properly. This parameter should take the full path of a log file used to
> output any debug messages. Other parameters of the main.cfg should be also
> correctly defined but for a simple GetCapabilities request, defining the
> logPath should be enough. You should obviously make sure that the IIS user
> is allowed to write the log file.
> I hope this answer will help to solve your issue,
> Best regards,
> [1] http://zoo-project.org/trac/changeset/680
>> Le 25 juin 2015 à 07:55, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit
>> Hi,
>> Greetings!!!
>> I have been trying to Install zoo kernel on IIS.
>> I was able to compile the zoo kernel and was able generate the
>> zoo_loader.cgi file.
>> I placed the zoo_loader.cgi and main.cfg file(modified the
>> ServerAddress ) in C:\inetpub\wwwroot\cgi-bin
>> Then through the command prompt I was able to generate same response as
>> we get by installing Apache Server.
>> I got the response as below :
>> c:\inetpub\wwwroot\cgi-bin>zoo_loader.cgi
>> Content-Type: text/xml; charset=utf-8
>> Status: 400 Bad request
>> <?xml version="1.0" encoding="utf-8"?>
>> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3
>> .org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> xml:lang="en-US" v
>> ersion="1.1.0">
>> <Exception exceptionCode="MissingParameterValue" locator="request">
>> <ExceptionText>Parameter <request> was not
>> specified</ExceptionText>
>> </Exception>
>> </ExceptionReport>
>> But when I try to access through browser
>> (http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0)
>> I get error as :
>> HTTP Error 502.2 - Bad Gateway
>> The specified CGI application misbehaved by not returning a complete set
>> of HTTP headers. The headers it did return are "".
>> It will be helpful for me if you could help me out with tis issue.
>> Regards,
>> Pankaj Pedram
>> 07506934293
>> pankaj.p.pedram at gmail.com
>> Zoo-discuss mailing list
>> Zoo-discuss at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150629/693aeabc/attachment.txt>
More information about the Zoo-discuss
