[Zoo-discuss] ZOO and Mapserver 6.4
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Nov 5 04:53:41 PST 2015
I will try to compile this on Windows and report back here.
-jeff
On 2015-11-05 8:30 AM, Jeff McKenna wrote:
> Hi Gérald, I am curious if you were able to get this MapServer 7 patch
> working with Windows.  Please let me know.
> -jeff
> On 2015-11-05 6:22 AM, Fenoy Gerald wrote:
>> Dear Luca,
>> as promised I take a quick look for trying to build the ZOO-Kernel
>> against the MapServer 7.0.0 version.
>> Strangely it worked with only few modifications in the source code, in
>> fact commenting 2 lines was enough to get it working. I probably tried
>> before the official release of the 7.0.0 version cause it seems to
>> work perfectly from what I can see. I’ve re-used the workshop material
>> in the VM and put in place the MapServer 7.0.0 version, then rebuild
>> the ZOO-Kernel and strongly it worked. Obviously I had to modify the
>> ZOOMakefile.opts to fit with my MapServer setup (mainly to make it
>> able to find the mapserver-config.h which was unfortunately not
>> installed by make install from the MapSever directory).
>> I’ve made all the modifications required available in the patch
>> attached to this mail to avoid having to edit any files during the
>> building procedure.
>> So I would like you to try the following, starting a fresh svn checkout :
>> patch -p0 < ms7.patch
>> autoconf
>> ./configure —with-python —with-js
>> —with-mapserver=<FULL_PATH_TO_MS_SOURCE_CODE>
>> make
>> sudo make install && sudo ldconfig
>> This suppose that you run make not directly in the MapServer source
>> code directory but in a build subdirectory. In other case you will
>> need to edit the configure.ac file to point to your build location (it
>> is required to find the mapserver-config.h file).
>> I have made only tests using the routing service from the ZOO-Project
>> workshop so there may be some issue for some specific services but I
>> don’t why we may have any issue in publishing something else than
>> lines (the result of the routing service is a set of lines).
>> I hope you can confirm that the MapServer 7.0.0 support is working, if
>> it is also working on your side, then I will apply a more general
>> patch to the SVN and commit it. I think that we should keep the source
>> code as it was for the 6.2.0 version which is working like a charm for
>> some years now and adapt for the 7.0.0 version by using ifdef block
>> around the two lines I’ve juste commented in the patch I provided.
>> I hope to hear back from you,
>> Best regards,
>>> Le 5 nov. 2015 à 10:26, Fenoy Gerald <gerald.fenoy at geolabs.fr> a écrit :
>>> Dear Luca,
>>> thanks a lot for coming back on this topic.
>>> I’ve discussed the issue I faced when passing to 7.0 with Thomas
>>> during the foss4g in Seoul and he told me that now we have to
>>> initialize the map object with some initializing functions dedicated
>>> to allocate memory. Indeed from what I was able to try some months
>>> back the ZOO-Kernel failed due to segmentation violation which should
>>> be caused by a memory part which was not correctly initialized.
>>> I will try to upgrade to MapServer 7.0 on a VM and will let you know
>>> what are the result.
>>> Best regards,
>>>> Le 5 nov. 2015 à 09:33, Luca Delucchi <lucadeluge at gmail.com> a écrit :
>>>> On 28 January 2014 at 11:12, Fenoy Gerald <gerald.fenoy at geolabs.fr>
>>>> wrote:
>>>>> Dear Luca,
>>>> Dear Gerald,
>>>> I'm back on this topic
>>>>> you should try using the following:
>>>>>> MS_LDFLAGS=/home/lucadelu/compilati/mapserver-6-4-1/build/libmapserver.so
>>>>> You kept the « -L » in what you gave initially.
>>>>> For the CFLAGS, I’m not sure this is correct as you said that you
>>>>> built Mapserver in some other place, so the
>>>>> "-I/home/lucadelu/compilati/mapserver-6-4-1/"  should point to the
>>>>> location where MapServer was built.
>>>>>> MS_CFLAGS=-DUSE_MS   -I/home/lucadelu/compilati/mapserver-6-4-1/
>>>> any news to compile zoo against mapserver 6.4.1? or in the worst case
>>>> did you try with mapserver 7?
>>>>> Hope this helps,
>>>>> Best regards,
>>>> ciao
>>>> Luca
>>>> http://gis.cri.fmach.it/delucchi/
>>>> www.lucadelu.org
>>>> _______________________________________________
>>>> Zoo-discuss mailing list
>>>> Zoo-discuss at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
>>> Gérald Fenoy
>>> http://wiki.osgeo.org/wiki/User:Djay
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
More information about the Zoo-discuss mailing list
