[Zoo-discuss] several instances zoo
Fenoy Gerald
gerald.fenoy at geolabs.fr
Mon Apr 11 02:52:32 PDT 2016
Hi Pablo,
you can have multiple instances of the ZOO-Kernel running on the same server.
If you want the two instance to share the same directory (so containing the same services), then you may simply rename the zoo_loader.cgi with another name and place it in the same directory.
If you want a different repository, by now, the only option is to place another ZOO-Kernel in another directory containing also the services allocated to this WPS instance.
I hope I have answered your questions correctly.
Best regards,
> Le 11 avr. 2016 à 04:15, pablo zader <pzader at gmail.com> a écrit :
> Hi list
> It is possible to have multiple instances of zoo running on the same server ?
> You can define different repositories services in a zoo installation and access each of them ?
> Thanks in advanced
> Pablo J. Zader
> Lic. en Cs. de la Computación
> pablo.zader at gmail.com
> "Los Grandes Hombres hablan sobre ideas...
> Los Hombres Promedio hablan sobre cosas...
> Los Hombres Pequeños hablan.. de otros Hombres.
> del libro Matemática estas ahi? A. Paenza "
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss
