[Zoo-discuss] Reg: Exception in DescribeProcess request
Anju Bajpai bajpai.anju at gmail.com
Mon Aug 1 01:22:22 PDT 2016
Dear Fenoy,
I created the folder and given IUsers and IISUsers all permissions, still
same error is coming.
It seems some stack overflow exception in GDAL. Can you suggest something.
Anju Bajpai
On Mon, Aug 1, 2016 at 1:46 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
wrote:
> Hello,
> sorry for the issue you face.
> In the main.cfg used to install on windows platform [1] the cacheDir is
> defined as c:/inetpub/tmp/ which means that this directory should exist
> before trying to access external ressources. This directory should be
> created or the line defining the cacheDir should be removed from your local
> main.cfg. I have also noticed that this directory is not created by the
> installer, so this have to be fixed directly in the installer also.
> I hope this helps.
> Best regards,
> [1] http://www.zoo-project.org/dl/win_main.cfg
> > Le 1 août 2016 à 09:57, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > I have installed ZOo in a 32 bit machine.the
> getcapabilities,describeprocess and execute request are giving correct
> output
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=HelloPy
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name@dataType=string
> > But when i am running the zoo-demo application the zoo kernel gets
> loaded but after running the buffer method it gives an access exception
> error
> > <?xml version="1.0" encoding="utf-8"?>
> > <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport
> > .xsd" xml:lang="en-US" version="1.1.0">
> >   <ows:Exception exceptionCode="InternalError">
> >     <ows:ExceptionText>Unable to run the Service. The message returned
> back by the Service was the following: Unable to open datasource
> `/vsimem/input_5048.json' with the following drivers.</ows:ExceptionText
> >   </ows:Exception>
> > </ows:ExceptionReport>
> > Anju Bajpai
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160801/6ed4ec10/attachment.html>
More information about the Zoo-discuss mailing list
