[Zoo-discuss] Reg: Exception in DescribeProcess request
Anju Bajpai bajpai.anju at gmail.com
Mon Aug 1 03:04:23 PDT 2016
Dear Fenoy,
Yes two files with extension zca and zcm got generated. The zca file is 0KB
and zcm 1KB.
Anju Bajpai
On Mon, Aug 1, 2016 at 2:34 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
wrote:
> Dear Anju,
> after you created the directory, is there any created file inside
> c:/inetpub/tmp after you try executing a service ?
> If no, it means there is an issue when the ZOO-Kernel try to create file
> in this directory. So you may try to remove the cacheDir line from your
> main.cfg file and rerun the same Execute request again.
> From the error message returned by the service, it seems that the
> ZOO-Kernel is not able to access the external ressource or is using cache
> but cannot use it properly.
> I hope this helps.
> Best regards,
> > Le 1 août 2016 à 10:22, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > Dear Fenoy,
> > I created the folder and given IUsers and IISUsers all permissions,
> still same error is coming.
> > It seems some stack overflow exception in GDAL. Can you suggest
> something.
> > Anju Bajpai
> > On Mon, Aug 1, 2016 at 1:46 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
> wrote:
> > Hello,
> > sorry for the issue you face.
> > In the main.cfg used to install on windows platform [1] the cacheDir is
> defined as c:/inetpub/tmp/ which means that this directory should exist
> before trying to access external ressources. This directory should be
> created or the line defining the cacheDir should be removed from your local
> main.cfg. I have also noticed that this directory is not created by the
> installer, so this have to be fixed directly in the installer also.
> > I hope this helps.
> > Best regards,
> > [1] http://www.zoo-project.org/dl/win_main.cfg
> > > Le 1 août 2016 à 09:57, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > > I have installed ZOo in a 32 bit machine.the
> getcapabilities,describeprocess and execute request are giving correct
> output
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=DescribeProcess&Version=1.0.0&Identifier=HelloPy
> http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Version=1.0.0&Identifier=HelloPy&DataInputs=a=My%20Name@dataType=string
> > > But when i am running the zoo-demo application the zoo kernel gets
> loaded but after running the buffer method it gives an access exception
> error
> > > <?xml version="1.0" encoding="utf-8"?>
> > > <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport
> > > .xsd" xml:lang="en-US" version="1.1.0">
> > >   <ows:Exception exceptionCode="InternalError">
> > >     <ows:ExceptionText>Unable to run the Service. The message returned
> back by the Service was the following: Unable to open datasource
> `/vsimem/input_5048.json' with the following drivers.</ows:ExceptionText
> > >   </ows:Exception>
> > > </ows:ExceptionReport>
> > > Anju Bajpai
> > > _______________________________________________
> > > Zoo-discuss mailing list
> > > Zoo-discuss at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160801/6363d227/attachment-0001.html>
More information about the Zoo-discuss mailing list
